Go to Post If everyone spent half as much time reading and understanding the rules as they do complaining, arguing, and disagreeing about rules, we might not even be having this discussion. - AmyPrib [more]
Unread 29-01-2011, 12:17
PeteG PeteG is offline
FRC #2084 (Robots by the C)
PeteG will become famous soon enough
Question Potentiometers in Java
Our team is trying to find a way to measure the position of our arm using a potentiometer. We're using Java this year and we can't find any classes that are for potentiometers.
Does anyone know the best way that we could program a potentiometer in Java to give us its position?
Unread 29-01-2011, 13:04
mwtidd's Avatar
mwtidd mwtidd is offline
AKA: mike
FRC #0319 (Big Bad Bob)
Re: Potentiometers in Java
I think you can use analog channel
Unread 29-01-2011, 17:57
Awesome, thanks, I assume you mean the AnalogChannel class (there are a few others like AnalogModule, AnalogTrigger, etc.).
Would we use getVoltage() or getValue()? It might be getVoltage() since (I think) potentiometers just limit the voltage when the knob is turned. I've never used potentiometers before, though.
Unread 29-01-2011, 18:53
sjspry sjspry is offline
FRC #1984
sjspry has a spectacular aura aboutsjspry has a spectacular aura aboutsjspry has a spectacular aura about
It shouldn't matter, you will just obtain different values. getValue will be something more akin to a "percent" (but in a range of integral values), while getVoltage will be un-scaled to be a voltage.
IIRC, getValue will give you more resolution, but overall it won't matter.
Unread 29-01-2011, 21:06
OK, we'll just pick one and go with it in the code. Thanks for your help.
