Go to Post When I was going down that one escalator that led to the field between the buildings and getting my first look at it, I felt like Dorothy walking into Oz. - Dr. Acula [more]
Unread 29-01-2011, 05:27
BornaE's Avatar
BornaE BornaE is offline
FRC #0842 (Formerly 39)
BornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant future
Minibot Simple Circuit
I have seen lot's of discussion on the forum about how to be able to retrieve the minibot after the match. You can use the following circuit with 2 household 2 way light switches (the one's that let you control a light from 2 places)
In the state the is seen in the diagram, the robot is off. when the robot is deployed, the Hostbot will flip switch1 which will turn on the motors to allow the minibot to climb.
When the minibot reaches the top of the pole, some mechanism will need to push on switch number 2 which will in effect turn the minibot off and let your monibot gracefully roll down the pole. As a bonus, this configuration will short out the 2 lead of your motors when it is off which will effectively create a break on the motors that will not let your robot gain much velocity on the way down. It will slowly slide All the way down the pole.
Please let me know if there is any clarification needed for this issue.
-Borna
-Borna Emami
Team 0x27
Unread 29-01-2011, 07:12
Jim Wilks Jim Wilks is offline
Electrical Engineer
AKA: Jim Wilks
FRC #1360 (Orbit Robotics)
Jim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond repute
Re: Minibot Simple Circuit
Good concept!
A couple of corrections. The switches you are using are called 3 way switches. The deployment is via switch 2 and the braked descent is via switch 1.
JGW
Unread 29-01-2011, 15:45
BornaE's Avatar
My bad on the "2way" vs "3way"
but, it does not make a difference which switch is used to deploy and to stop. depending on the way the motor is wired, one switch makes it go up if triggered first, while the other makes it go down if triggered.
Originally Posted by jgw View Post
Good concept!
JGW
-Borna Emami
Team 0x27
Unread 29-01-2011, 18:59
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
The motor is also shunted ("braked") while in un-deployed state. This could also be a design advantage when trying to engage the pole.
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
Unread 29-01-2011, 19:41
zbanks zbanks is offline
AKA: Zach Banks
FRC #0529 (Mansfield Hornets)
zbanks is an unknown quantity at this point
Send a message via AIM to zbanks
Although we have yet to start the minibot, I've been thinking about using a layout like this to control the motors. I quickly sketched it up to share:
S1 is the "pole" switch, which is activated while the minibot is touching the pole.
S2 is a switch that is activated at the top of the run. It disconnects power & shunts the motors together, slowing them down.
S2 is tricky, though. It needs to be a SPDT toggle switch, not just momentary. Also, it needs to be "break before make" style, otherwise you'd short the battery & blow the fuse.
Unread 29-01-2011, 20:08
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
S2 can be a 3-way light switch.
