Go to Post Maybe if we get lucky [the GDC] will just say chute door. - IronicDeadBird [more]
Unread 29-01-2011, 18:14
Android's Avatar
Android Android is offline
FRC #2443 (Blue Thunder)
Team Role: Photography
Android is an unknown quantity at this point
Bypass Switch That Will Lower A Lift After The Game has ended.
At the end of the game, if our lift is at full extension, can we have a bypass switch that will lower the lift after the game has ended so we can get the robot off the field?
We are aware that controls are cut off from the robot at the end of the match. We want to know if there can be a button (Either on the robot, or joy pad) that we can press that will lower a lift we have on our robot for easy retrieval as well as a safety hazard.
Unread 29-01-2011, 18:19
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: Bypass Switch That Will Lower A Lift After The Game has ended.
The robot will be disabled when the match ends. Regardless of where you place the switch, you will not be able to power a motor after the match ends.
Unread 29-01-2011, 19:34
Android's Avatar
Technically the robot will still have power, we would only have our controls cut off from the robot.
Unread 29-01-2011, 19:35
nitneylion452's Avatar
AKA: Joe Lee
See this thread.
Unread 29-01-2011, 19:42
Android's Avatar
Sorry, that persons also from my team.
I just thought if we opened several posts on the same subject we'd get different answers.
Unread 29-01-2011, 19:44
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
If the robot is in the disabled state, your Jaguars, Victors and Spikes can not power anything. Your switch cannot be in the power pathway between any of these devices and the motors.
Unread 29-01-2011, 20:03
Android's Avatar
Can you clarify:
"Your switch cannot be in the power pathway between any of these devices and the motors."
Unread 29-01-2011, 20:06
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Check the Robot section of the manual. If you look and can't find it I'll give you the specific rule, but the language I used should be helpful.
Unread 29-01-2011, 20:15
Team#2057-Vegas's Avatar
Team#2057-Vegas Team#2057-Vegas is offline
Team2057LasVegas
AKA: Justin Major
FRC #2057 (AV CyberBulls)
Team#2057-Vegas can only hope to improve
team did a quick discussion on this.. what we came up with:
you could have a 2nd thing wired from your power board with a light switch for direct power to the motor as well.. just make sure its off during the match.. that way you have 2 sets of power going to that motor.. 1 will be for after the match.. if you cant find the answer i say try it and if they say take it off its simple enough to remove.
best of luck.. and great idea (:
-2057
Justin Major
2057 Team Leader
"We will kick you off our pasture" -- 2057 Motto
Unread 29-01-2011, 20:17
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
-2057
Illegal. See <R48>
Unread 29-01-2011, 20:31
Android's Avatar
Thanks guys!
In rule <R48> it only states that all motors must be connected to a speed controller, it says nothing about bypassing the speed controller at the end of the match.
One of my mentors also came up with the sketch.
Maybe it can help out a little.
http://www.chiefdelphi.com/forums/at...2&d=1296350411
Unread 29-01-2011, 20:32
ATannahill ATannahill is online now
AKA: Alex Tannahill
Kevin is correct. But, if you could easily diconnect the wires (sure as have a male-female connection in line) and hook them to a handheld battery, you might be able to get away with not violating T15. If you do try this, you need to be able to do it in a timely maner.
- Arizona North
Unread 29-01-2011, 20:36
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Good suggestion Alex, I could see some chance of this being legal. I would ask the Q&A to be sure though.
Unread 29-01-2011, 20:40
Android's Avatar
Thanks!
But in rule <R48> it only states that a motor needs be connected to a speed controller, it says nothing about bypassing it at the end of the match.
One of our mentors also came up with this sketch. Maybe it can clarify things.
Unread 29-01-2011, 20:43
Android's Avatar
Thanks!
