Go to Post Lighten it up a little to bring it in under the 120 pound weight limit, and I think you will have something there! - dlavery [more]
Unread 29-01-2011, 23:27
NyCityKId's Avatar
NyCityKId NyCityKId is offline
That Weird Kid
AKA: Andre Dunkley
FRC #1601 (Quantum Samurai)
NyCityKId is a splendid one to beholdNyCityKId is a splendid one to beholdNyCityKId is a splendid one to beholdNyCityKId is a splendid one to beholdNyCityKId is a splendid one to beholdNyCityKId is a splendid one to beholdNyCityKId is a splendid one to beholdNyCityKId is a splendid one to behold
Send a message via AIM to NyCityKId
<R92-N> What counts as a common household switch?
I was wondering if anyone knew if a double pole double throw switch counts a common household switch.
Unread 29-01-2011, 23:31
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Re: <R92-N> What counts as a common household switch?
http://forums.usfirst.org/showthread.php?t=16347
Originally Posted by GDC
For the purposes of the 2011 competition, a common household light switch is any electrical switch that would normally be mounted in a wall outlet box with household wiring, typically available at a home supply center (e.g. Lowes or Home Depot).
Minor modifications of the switch (e.g. removing the mounting tabs) are permitted, as long as the basic structural integrity and overall safety of the switch are not compromised.
I would guess that, if you got it from a local home supply store, and it is the kind that would fit into a wall box (e.g. a 4-way switch), it would be legal.
Kettering Motorsports
Unread 29-01-2011, 23:59
NyCityKId's Avatar
That Weird Kid
AKA: Andre Dunkley
Thank you very much and I guess I will have to go switch hunting. The better question would've been whether they have DPDT switches that are sold as household switches.
Unread 30-01-2011, 16:56
There are some DPDT switches but they are hard to find.
Unread 30-01-2011, 18:43
What will you be using the switch for? A standard 4-way light switch is common enough.
Unread 30-01-2011, 22:35
NyCityKId's Avatar
That Weird Kid
AKA: Andre Dunkley
I want to wire the switch so that it reverses polarity. I plan to use this on the minibot so that it automatically comes down once it hits the pressure plate.
Unread 30-01-2011, 22:39
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
Haha, what would count as Dean's common household switch?
1058 PVC Pirates 2016 - xxxx
Unread 30-01-2011, 22:40
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Might be easier to just use two switches....3 way light switches....one turns it on, the other turns it off. Since they likely want to be in different places on the minibot. Or will your minibot not roll down the pole if unpowered?
Unread 30-01-2011, 22:56
NyCityKId's Avatar
That Weird Kid
AKA: Andre Dunkley
Im not sure yet. we don't work on Sundays so i haven't had a chance to try it out. once i play with the gear ratios there may be no need to have this set up.
Unread 30-01-2011, 23:06
Yep, that's exactly what a 4-way light switch will do for you.
Unread 30-01-2011, 23:13
NyCityKId's Avatar
That Weird Kid
AKA: Andre Dunkley
Nice! thanks. Now would this count as a single household switch or two? It is kindof 2 switches in one.
Unread 30-01-2011, 23:29
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
It would count as one switch. It is a single switch in a single housing.
