Go to Post Screws come even smaller, #0000 - 160 at Small Parts.They're about $4 each, and made by elves. - DonRotolo [more]
Unread 13-01-2011, 12:50
Digmaster Digmaster is offline
AKA: Thomas Luppi
FRC #2827 (Srown City Robotics)
Digmaster is an unknown quantity at this point
FRC 2011 v25 cRIO image
For the life of me I am unable to find the location of v25 cRIO image. any assistance on this matter? opening up the image tool shows no images available.
Unread 13-01-2011, 12:52
Re: FRC 2011 v25 cRIO image
Usually that means the required language update hasn't been installed.
Unread 13-01-2011, 13:14
sircedric4's Avatar
sircedric4 sircedric4 is offline
AKA: Darren
no team (The SS Prometheus)
sircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond repute
We had this same issue last night, and that's when I realized our students didn't read and do every line in the Getting Started series of manuals. There is a line under "Install LabVIEW 8.6.1 and Associated Components", number 8 which says "Install updates, see above".
Its incredibly easy to miss, and it also doesn't have a link to the updates either. You probably just need to install the Labview Utilities update from NI, located here: http://joule.ni.com/nidu/cds/view/p/id/2262
I would also make sure you got the other updates on this page installed. http://usfirst.org/roboticsprograms/....aspx?id=18758
We ran into an issue after this that we couldn't resolve last night that would not allow the cRIO to properly image, just return an error 56. There's a topic one of the students posted up here that we'll try the solutions posted there tonight. I am unsure if the order of updates and installation is important, so you may end up in the same place we are now.
Unread 29-01-2011, 15:25
BigJ BigJ is online now
AKA: Josh P.
BigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond repute
We are having this same problem (programmers are off to a slow start). The Imaging tool shows no images to load. We have installed, updated, un/reinstalled, and reupdated.
EDIT:
We are planning to develop in Windriver, we have installed the LabVIEW and tools from the DVD, and run the LabVIEW and Utilities updates (I assumed the DriverStation update is only for computers we plan to use at the driver station).
Unread 29-01-2011, 19:16
And you installed from the Windriver DVD.
And you installed the Windriver Update?
No need for the driver station unless you want to use it locally.
Unread 30-01-2011, 00:44
AKA: Josh P.
Yes, and yes. We just don't see an image file in the list area where you'd pick one.
Unread 30-01-2011, 08:23
Is the cRIO Imaging Tool set to Windriver?
It won't show up if the wrong language is selected, because there are different unique images for the three major programming environments.
Here's where the images for each of the languages is supposed to reside.
http://www.chiefdelphi.com/forums/sh...24&postcount=4
See if your's is in the Windriver folder.
Unread 30-01-2011, 14:24
AKA: Josh P.
Thanks, I'll have the team check the location!
