Go to Post A lot of people forget this when posting, but your posts here on ChiefDelphi will more or less be here forever. Do you really want that post you just be made to be on the Internet forever?... Post wisely... - artdutra04 [more]
Unread 30-01-2011, 00:57
bladetech932's Avatar
bladetech932 bladetech932 is offline
Programmer of awesome
AKA: Jon
FRC #0932 (Circuit Chargers)
bladetech932 is on a distinguished road
Question Analog voltage
Could someone confirm that the analog input is 0-5v?
Expect the best, Prepare for the worst
Unread 30-01-2011, 02:02
Re: Analog voltage
On the cRIO?
It is -10V to +10V input and a 5V power supply.
Unread 30-01-2011, 13:32
AKA: Jon
Re: Analog voltage
So I'm going to need a 0-10v input?
Unread 30-01-2011, 13:35
Re: Analog voltage
Nope. You can use anything that fits within -10 to +10, including 0 to 5
Unread 30-01-2011, 13:41
AKA: Jon
Re: Analog voltage
I've never use an analog sensor before what am going to get out of the vi?
Unread 30-01-2011, 14:06
StevenB StevenB is offline
is having FRC withdrawal symptoms.
AKA: Steven Bell
StevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond repute
Re: Analog voltage
I suggest you start here: http://decibel.ni.com/content/docs/DOC-14724
Need a physics refresher? Want to know if that motor is big enough for your arm? A FIRST Encounter with Physics
2005-2007: Student | Team #1519, Mechanical Mayhem | Milford, NH
2008-2011: Mentor | Team #2359, RoboLobos | Edmond, OK
2014-??: Mentor | Looking for a team...
Unread 30-01-2011, 16:45
AKA: Jon
Re: Analog voltage
I know how to wire/program gyros, accelerometers, and encoders.
i was asking about analog inputs they dont have pre-written VIs for
Unread 30-01-2011, 18:19
Re: Analog voltage
There's a complete set of them.
WPI Robotics Library >> IO >> AnalogChannel
The Analog Get Voltage function is probably the one you'll be using. As the name implies, it returns the voltage present on the Analog Input pin.
Unread 30-01-2011, 18:27
AKA: Jon
Re: Analog voltage
Alright, i can work with that. thank you all!
