Go to Post That box you think you see is only an illusion. - Alan Anderson [more]
Thread Tools Rating: Thread Rating: 13 votes, 4.69 average. Display Modes
Unread 29-01-2011, 20:57
agentace agentace is offline
FRC #2522
agentace is an unknown quantity at this point
Java Encoder Problem
I am new to Java, but have a new mentor who is fluent in Java but not the FRC plugins. We have been trying to get the encoders to update their raw values on the Java debugging screen but have been only getting the output of 0.0. We know the encoders work because they work fine in LabVIEW, but not Java. This is the code I have so far:
private Encoder rightEncoder = new Encoder(4,5,4,6,true,CounterBase.EncodingType.k4X) ;
private Encoder leftEncoder = new Encoder(4,7,4,8,true,CounterBase.EncodingType.k4X) ;
and then in teleop periodic:
System.out.println(" le="+leftEncoder.get()
+" re="+rightEncoder.get());
Am I missing anything that would keep the encoders from posting the right values?
Thanks.
Pete
Team 2522
Unread 29-01-2011, 21:07
Patrick Chiang Patrick Chiang is offline
Programming
FRC #3070 (Team Pronto)
Patrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to all
Re: Java Encoder Problem
I've personally never had to deal with encoders before, but here's one thing you can try: see if doing rightEncoder.start(); leftEncoder.start(); does anything. If that fails, I'm as puzzled as you are.
Unread 30-01-2011, 03:13
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Patrick is correct inside of robotInit() you should call the start() method of each encoder that you are using. After that you should get values when you call getDistance().
One thing to note is that my team has had problems with getRate() and had to write our own getRate() method to get accurate results.
Unread 30-01-2011, 10:14
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Yes: the encoder.start()... 3 programmers literally spent 3 hours trying to figure that out... But it turned out that we also wired it up all wrong because I am an idiot... But the team captain said my soldering was pretty good.
Here are the current revisions of our code: you will be surprised how long I had to fight to get the other programmers to agree on using arrays... They thought arrays will just complicate things. Now since I was the lead programmer, I pretty much said "I am doing it" and after I did it, they liked it.... -__-;;
BTW the DataStructure is abridged; I only included the encoder stuff and took the rest out.
CVEncoder.java:
package edu.wpi.first.wpilibj.Robot2011.Perceive;
import edu.wpi.first.wpilibj.Encoder;
import edu.wpi.first.wpilibj.Robot2011.DataStructure;
 * @author Robotics2011
public class CVEncoder
    private Encoder spin[];
    private int numOfEncoders;
    public CVEncoder(int n)//takes in number of encoders
        numOfEncoders = n;
        if(numOfEncoders > 8)
            numOfEncoders = 8;
        else if(numOfEncoders < 0)
            numOfEncoders = 0;
        spin = new Encoder[numOfEncoders];
        int counter = 1;
        for(int i = 0; i < numOfEncoders; i ++)
            spin[i] = new Encoder(i + counter, i + counter + 1);
            counter ++;
            spin[i].start();//took 3 hours to figure this out, but electronics was still at fault
    public void setRotation(double circumference, int c)//to caculate rate and dist; circumference in feet
        spin[c].setDistancePerPulse(circumference / 360.0);//cirumference divided by 360 degrees [per pulse]
    //rate - ft/s
    //dist - ft
    //direction - 1 is forward, -1 if backward
    public void update(DataStructure dat)//update inhited privates with dist, dir, and rate
        for(int num = 0; num < numOfEncoders; num ++)
            //Direction formatting
            double direction = 0;
            if(spin[num].getStopped() == false && spin[num].getDirection() == true)//allegedly, Encoder class returns negative int for forward
                direction = 1.0;
            else if(spin[num].getStopped() == false && spin[num].getDirection() == false)
                direction = -1.0;
            dat.setDirection(num, direction);
            dat.setDistance(num, spin[num].getDistance());
            dat.setRate(num, spin[num].getRate());
            dat.setStopped(num, spin[num].getStopped());
            dat.setPulses(num, spin[num].get());
    public void neutralize(DataStructure dat)
            spin[num].stop();
            spin[num].start();
            spin[num].reset();
        update(dat);
    public int numberOfEncoders()
        return numOfEncoders;
DataStructure.java:
package edu.wpi.first.wpilibj.Robot2011;
public class DataStructure
    //Encoder Variables
    private int numEncoders;//set number of encoders
    private double rate[];
    private double distance[];
    private double direction[];
    private double pulses[];
    private boolean stopped[];
  public DataStructure()
        //Setting Encoder Variables to 0
        numEncoders = 0;
public void constructEncoders(int num)
        numEncoders = num;
        rate = new double[numEncoders];
        distance = new double[numEncoders];
        direction = new double[numEncoders];
        pulses = new double[numEncoders];
        stopped = new boolean[numEncoders];
        for(int i = 0; i < numEncoders; i ++)
            rate[i] = 0.0;
            distance[i] = 0.0;
            direction[i] = 0.0;
            pulses[i] = 0.0;
            stopped[i] = true;
//Start Encoder Accessors and Manipulators
    public void setRate(int num, double x)
        rate[num] = x;
    public double getRate(int num)
        return rate[num];
    public void setDistance(int num, double d)
        distance[num] = d;
    public double getDistance(int num)
        return distance[num];
    public void setDirection(int num, double d)
        direction[num] = d;
    public double getDirection(int num)
        return direction[num];
    public void setPulses(int num, double i)
        pulses[num] = i;
    public double getPulses(int num)
        return pulses[num];
    public void setStopped(int num, boolean b)
        stopped[num] = b;
    public boolean getStopped(int num)
        return stopped[num];
    //End Encoder Accessors and Manipulators
Unread 08-02-2011, 10:17
java4first java4first is offline
(Java) Programming Mentor
AKA: Stu
FRC #0501 (Power Knights)
java4first is an unknown quantity at this point
Thank you for the code snippets ... I'll defer on the topic of arrays for now.
But, I wondered if the encoders you are using are the Andy Mark ones we have and are planning to use:
US Digital E4P-250-250-D-D-D-B encoder am-0174
http://www.andymark.com/ProductDetai...ctCode=AM-0174
That will at least save me from wondering about code differences vs. hardware differences.
Thanks!
Stu
Unread 08-02-2011, 11:13
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Thanks!
Stu
We are using the exact same ones
Unread 08-02-2011, 22:02
CapnKernul CapnKernul is offline
FRC #1515
CapnKernul is an unknown quantity at this point
Our team ran into the same exact problem. For some reason, the FPGA counting mechanism doesn't work right. Instead of using the CounterBase.EncodingType.k4X encoding type, try CounterBase.EncodingType.k1X instead. Worked for us.
Good luck!
