Go to Post I am really glad that FIRST gives teams the choice to use either students or adults in this role. - dtengineering [more]
Unread 30-01-2011, 10:25
Team#2057-Vegas's Avatar
Team#2057-Vegas Team#2057-Vegas is offline
Team2057LasVegas
AKA: Justin Major
FRC #2057 (AV CyberBulls)
Team#2057-Vegas can only hope to improve
Lightswitches
Rule <92> states that you can use any household lightswitch that fits into a lightswitch box at home.. I'm having a little trouble interpreting the rule though.. can you use a push-switch (kinda like the offbutton of the power distribution board) and a pull switch? (like a lamp)
Justin Major
2057 Team Leader
"We will kick you off our pasture" -- 2057 Motto
Unread 30-01-2011, 10:52
Re: Lightswitches
Originally Posted by GDC
For the purposes of the 2011 competition, a common household light switch is any electrical switch that would normally be mounted in a wall outlet box with household wiring, typically available at a home supply center (e.g. Lowes or Home Depot).
http://forums.usfirst.org/showthread.php?t=16347
If it fits that description, it's good. If not, it's not.
Unread 30-01-2011, 11:00
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: Lightswitches
I've never seen a lamp style switch that goes into a switchbox in a wall.... If you can find one it's legal, if not then no.
I've also never seen a single push button switch, although rocker style switches would probably work in a similar manner and are available.
