Go to Post Silly, Silly, don't you realize there are no borders in FIRST:) - HW [more]
Unread 28-01-2011, 18:30
Left Justified Left Justified is offline
AKA: Calvin Norman
FRC #2647
Left Justified is an unknown quantity at this point
Multiple buttons on a single motor
Apologies if this seems like a stupid question, but:
My team decided to go with a traditional tankdrive for our bot, and I was wondering if it is possible to set multiple buttons to the same motor.
I was hoping to have the triggers on our joysticks make the motor driving the arm spin in opposite directions, and was having trouble figuring out how to do this.
Thanks in advance.
Unread 28-01-2011, 19:59
Re: Multiple buttons on a single motor
I'm sure what you are asking for is possible, and it's probably even easy. A more precise description of what you want would help. Do you want the left joystick trigger to run a motor in one direction and the right joystick trigger to run it in the other direction? Do you want the motor to stop when both triggers are released? Do you have any preference for what happens when both triggers are pressed?
Unread 28-01-2011, 20:08
bladetech932's Avatar
bladetech932 bladetech932 is offline
Programmer of awesome
AKA: Jon
FRC #0932 (Circuit Chargers)
bladetech932 is on a distinguished road
Use the motor devref and just split the wire to go to two different set speed vis in two different case structures
Expect the best, Prepare for the worst
Unread 29-01-2011, 13:28
AKA: Calvin Norman
FRC #2647
@Alan: I want pretty much what you said. I was hoping to have the left trigger make the motor go forward and the right trigger do the opposite.
Unread 30-01-2011, 10:56
I was right, what you want is easy.
Name:	button motor.jpg
The triangular "Select" functions might be unfamiliar. The help describes them this way:
Returns the value wired to the t input or f input, depending on the value of s. If s is TRUE, this function returns the value wired to t. If s is FALSE, this function returns the value wired to f.
So when neither button is pressed, the motor is set to 0. When the forward button is pressed, the motor is set to 1 (full speed forward -- change the constant if you want some other speed). When only the reverse button is pressed, the motor is set to -1 (full speed reverse -- change it if you want).
