Go to Post Know what really grinds my gears? Metal Shavings. - Briansmithtown [more]
  #91   Spotlight this post!
Unread 27-01-2011, 15:06
koo_04 koo_04 is offline
FRC #2493
koo_04 will become famous soon enough
Re: How should we wire the photoswitchs?
Anyone notice in Team update 5 this addition?
<R60> Solenoid Breakout outputs shall be connected to pneumatic valve solenoids or photoelectric sensors, PN 42EF-D1MNAK-A2 only. No other devices shall be connected to these outputs.
Thanks to some of the discussion here, it was noted that sagging batteries would cause a brown out condition on the sensors. R60 now allows a team to add a 9472 solenoid module connected to the +24 volt output of the PD to power the line following sensors with a regulated +24 volts. Thank You FIRST Engineering for the great find and fix.
Thanks a ton! I will try this tonight. If it works, I will report back.
  #92   Spotlight this post!
Unread 27-01-2011, 15:14
In general light conditions should not matter since these have their own IR source, however, if your lighting conditions have a significant IR output or there are night vision security cameras, you may have a problem with ambient light.
  #93   Spotlight this post!
Unread 28-01-2011, 22:42
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
@Al and @Phil, just wanted to let you know we got the sensors working thanks to your inputs. It was mostly just a matter of getting them calibrated correctly.
The views expressed are mine and should not be construed to represent the views of anyone else.
  #94   Spotlight this post!
Unread 29-01-2011, 09:26
wazcodez's Avatar
wazcodez wazcodez is offline
AKA: Megh Suthar
FRC #2076 (Blackscots)
wazcodez is infamous around these partswazcodez is infamous around these parts
Send a message via MSN to wazcodez
I tried to run example code given by ni !
we had sensors lined up exactly as document, we ran the robot, and wheels were turning it in opposite direction !
and driver station gave an error
:: too many loops
another thing tht when when we put tape on the sensors they led changed the color !
robot was way too fast almost caused injury any idea how to slow it down ?
if u guys programed, can someone send me the code ... bec. i can't understand the example code provided to make changes
thanks
" When you copy from one source it's called plagiarism when u copy from multiple it's Research .. ! " - Megh Suthar
  #95   Spotlight this post!
Unread 29-01-2011, 09:43
Richard,
I will slide you over to the success column. Good luck!
  #96   Spotlight this post!
Unread 29-01-2011, 10:03
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
First question...
How does the robot drive in teleop? Does it go in the correct directions forward/rev, turn etc. This must be correct before auto. What about speed? Our robot is pretty fast in teleop, but still very managable in Auto.
Next: How was the robot positioned when you started auto? Were the sensors on the line etc. If not, the robot WILL turn.
The fact that this surprizes you means you have not read the instruction on how to calibrate them. THIS IS IMPORTANT. Find the small sheet of paper that came with them and read what the LED's mean. Until you adjust the sensitivity to be correct, they are worthless.
:: too many loops
thanks
Phil Malone
http://www.GEARSinc.org
  #97   Spotlight this post!
Unread 29-01-2011, 12:06
CaptainKemp CaptainKemp is offline
AKA: Morton
FRC #0888 (Robotiators)
CaptainKemp is an unknown quantity at this point
Hey,
I have looked at all of the posts so far and I have checked and my wiring looks correct for my photoswitches but one of my sensors is flashing yellow and then orange over and over. I looked it up online and it said something about a teach mode. Can anyone help me out by telling me how to teach it or if that is not what is happening?
Thanks
Morton
Morton
Team 888
"Any sufficiently advanced technology is indistinguishable from magic." - Clarke
  #98   Spotlight this post!
Unread 29-01-2011, 12:24
PhilBot's Avatar
AKA: Phil Malone
Flashing orange means you have probably powered your signal wire by mistake.
You say "my wiring looks correct". How did you verify it? (Looking isn't enough with electrical). When you post for help, it's no use saying "I did everything correct". We all think that. You really need to say what steps you took to verify correct wiring. That way we can suggest the ones you didn't take.
eg: Did you try unplugging the PWM cable and leaving just the power connected? This would ENSURE that you are not accidentally powering the signal line. I suspect that the blinking wil stop if you do this, which means you may have plugged the PWM cable in incorrectly. It's easy to do with the DSC cable clamps. Tripple check it. Sensor's black wire goes to WHITE PWM wire, which goes to the inner most pin (furthest from the edge) of the DSC connector.
Originally Posted by CaptainKemp View Post
Hey,
Thanks
Morton
Phil Malone
  #99   Spotlight this post!
Unread 29-01-2011, 12:50
AKA: Morton
As many people would assumed, looking correct is not just looking at it. I re-did my wiring a couple times and tried many different I/O Ports to see if I was wiring the power into the signal as many other people have said this. Reposting an old problem would be silly and thats why I didn't. The signal is going to the signal pin on the Digital IO Board (the innermost pin). The power is the same for all of the photoswitches coming from the Power Distribution Board. The white wire from the photoswitch is connected to the white signal wire on the PWM.
I was wondering if people knew anything about the teach mode because I was trying to find the calibration screw and turned the front black piece. Now when I turn it on it is always flashing between the yellow and the orange lights.
Thanks,
Morton
Morton
Team 888
  #100   Spotlight this post!
Unread 29-01-2011, 17:48
wazcodez's Avatar
AKA: Megh Suthar
First question...
1. we ran the robot it in atonoumus ...
2. robot runs perfectly on tele op
3. you can see led change color as shinig tape is provided (meaning calibrarted)
4. code was used from ni (default robot frame work)
1. if any one has made thier own code regarding line tracker.... can you please please provide us as we only have one guy doing programming and he is new to labview as well
Thanks Phil bot for your anwser
error :: too many loop for robot drive
  #101   Spotlight this post!
Unread 30-01-2011, 02:44
FRC #2493
Well, rsisk and I have gotten them working just fine. Now we have an issue that the carpet seems to be reflecting more then the tape? We are completely unsure of what is going on. If someone can make/has a tutorial, video or typed with pictures, that would AWESOME. If I had gotten these to work myself. I would be making it.
  #102   Spotlight this post!
Unread 30-01-2011, 11:22
PhilBot's Avatar
AKA: Phil Malone
You didn't say whether you tried unplugging the PWM cable to see if it stopped blinking, so I'm still not convinced that you don't have a wiring problem....
However, the black slot on the front IS the Callibrate adjustment, so you use this to set the sensor for your field. (I've not heard of a LEARN mode for this sensor.... but who knows).
Once you stop the flashing, Calibration is pretty simple. Put the sensor over the carpet. Turning the screw all one way should make the LED go green (this is the LEAST SENSITIVE setting).
Now position the sensor over the tape. Slowly turn the screw the other way until the LED switches to Orange. Turn it a little further, and then move the sensor over the carpet again, it should go back to green.
It may take some tweaking but you want to ensure that the LED is green over the carpet, and orange over the tape.
Note : My experience is that most students assume that "looking correct" IS "correct". I don't always track down credentials before answering a post, but base my reply on what's written. Sorry.
Phil.
Thanks,
Morton
Phil Malone
  #103   Spotlight this post!
Unread 30-01-2011, 12:24
AKA: Morton
No its fine, I know where you were coming from. When i pulled out the PWM cables it did stop flashing but I checked the wiring again and the white wire goes to the white wire. I don't know where else the wiring could go wrong because it is only the white wire that is connected to the PWM and then to the D I/O.
Can you think of any other reason past the wiring that may cause that or is it just the wiring because otherwise I am at a loss for answers.
Thanks
Morton
Team 888
  #104   Spotlight this post!
Unread 30-01-2011, 12:34
AKA: Morton
Disregard my last comment. I found the problem. We had a bad PWM cable that touched the signal to the power which caused it to go into the short circuit protection state. We replaced the PWM cable and now its working fine.
Thanks all
Morton
Team 888
  #105   Spotlight this post!
Unread 30-01-2011, 13:52
AKA: Morton
Okay, so now that the wiring is fixed, our calibration is now not working.
We believe that we were not supposed to turn the tuning knob over the ridge on the circle but we did before we realized this. The one photoswitch that we did not do this to is now working perfectly but the other two are not.
Can anyone tell me how you would reset the calibration on the photoswitch, or how to calibrate it once you passed the ridge, or if the photoswitches are now broken beyond repair?
Thanks
Morton
Team 888
