Go to Post YES! I am a MENTOR. Not a chaperone. I am busy all day, I don't want to deal with the stupidity that may or may not go on at night. Besides, I might see something as a cool physics experiment, where a chaperone might see someone dropping pop cans down the stair wells. - Not2B [more]
Unread 29-01-2011, 15:33
takiko1996's Avatar
takiko1996 takiko1996 is offline
FRC #2443 (Blue Thunder)
takiko1996 is an unknown quantity at this point
robot retrievel
At the end of the game, if our lift is at full extension, can we have a bipass switch that will lower the lift after the game has ended so we can get the robot off the field?
Unread 30-01-2011, 11:41
Re: robot retrievel
You would have to make it a mechanical "bypass". You will not be permitted to apply power to any motors after the match is over.
Unread 30-01-2011, 11:46
Hellfeier675's Avatar
Hellfeier675 Hellfeier675 is offline
FRC #0675 (Tech High Robotics Syndicate)
Hellfeier675 is an unknown quantity at this point
Re: robot retrievel
If you're using pneumatics however, you could just have the solenoid release right as the match ended.
-"Guys it's so inconvenient, Delphi is down at 3 am.... Hey I was bored last night!"
