Go to Post The robots are just vehicles taking kids on a ride to STEMville. - FTC5110 [more]
Unread 30-01-2011, 13:20
de_ de_ is offline
AKA: Dave Edwards
FRC #1310 (Runnymede Robotics)
de_ is a jewel in the roughde_ is a jewel in the roughde_ is a jewel in the roughde_ is a jewel in the rough
Dewalt 3 speed gear ratios ?
Anyone happen to know what the gear ratios are on the typical Dewalt 3 speed drills ? If you happen to know specifically for a DC940, all the better but anything would be useful.
Unread 30-01-2011, 13:36
Teched3 Teched3 is offline
Hodge1
FRC #0175 (BuzzRobotics)
Teched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud of
Smile Re: Dewalt 3 speed gear ratios ?
do a search on google for the DeWalt drill, and the speed specs will be listed. We have done DeWalt/CIM drives, and the difference between 2nd and 3rd wasn't very much. The 940 is a little better, but IMO is not needed.
Sweat the details
Why is there never enough time to do it right, but always enough time to do it again!
Even if you're on the right track, if you sit still, you'll get run over!!!
Unread 30-01-2011, 13:49
StevenB StevenB is offline
is having FRC withdrawal symptoms.
AKA: Steven Bell
StevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond repute
Start with the "Nothing But Dewalts" whitepaper.
Need a physics refresher? Want to know if that motor is big enough for your arm? A FIRST Encounter with Physics
2005-2007: Student | Team #1519, Mechanical Mayhem | Milford, NH
2008-2011: Mentor | Team #2359, RoboLobos | Edmond, OK
2014-??: Mentor | Looking for a team...
ajlapp ajlapp is offline
AKA: Anthony Lapp
None #0118 (Team RUSH and Robonauts)
ajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond repute
12, 16 and 48:1 if I recall correctly.
If building for a CIM you lose one 4:1 stage, leaving you 3,4 and 12:1.
Anthony Lapp
FIRST Engineering Mentor
Owner/Operator 221 Robotic Systems
221 Robotics Systems - Quality Hardware, Made in the USA
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Team 1 --> 94 --> 68 --> 221 --> 857 --> 27 --> 118
Design Engineer/Fabricator and 17 year vet
Team Rush (FRC27) and Robonauts (FRC118)
Unread 30-01-2011, 14:25
de_ de_ is offline
AKA: Dave Edwards
Thanks guys.
White paper drill is 47:1, 15:1, 12:1. Sorry I had forgot about that from years ago.
DC940 is definitely different as its pinion gear is different from the first planetary gear (unlike the drill in the white paper). But thats close enough for now. If I remember all three planetary sets are identical though.
I have no idea where on the internet they would list internal gear ratios of dewalts unless the dewalt parts lists show it which is not too likely as they would list just the gear box, not the 3 planetary sets in the gearbox. If anyone knows otherwise, let me know.
Unread 30-01-2011, 15:18
Hodge1
The drill lists the output speeds as 500,1200 and 2000. Ratios would be---
1:2.4:4, quite a bit different than the NBD white paper. Output speed and torque can then be calculated based on the motor you choose to mount.
Sweat the details
Unread 30-01-2011, 15:46
maddoctor90's Avatar
maddoctor90 maddoctor90 is offline
AKA: Matt
FRC #2481 (Roboteers)
maddoctor90 is a splendid one to beholdmaddoctor90 is a splendid one to beholdmaddoctor90 is a splendid one to beholdmaddoctor90 is a splendid one to beholdmaddoctor90 is a splendid one to beholdmaddoctor90 is a splendid one to beholdmaddoctor90 is a splendid one to behold
The following website sells the Dewault gearboxes and has unofficial specifications listed. I am not sure how accurate they are, but it might be worth looking at.
http://www.robotmarketplace.com/prod...walt_main.html
Unread 30-01-2011, 16:23
Mark Sheridan's Avatar
Mark Sheridan Mark Sheridan is offline
Head Mentor
FRC #3476 (Code Orange)
Mark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond repute
We are using the Dc940ka gearbox with the FP motor. An unofficial source estimates the no load rpm of the dewalt motor to be about 20,000 rpm (about same as FP motor fyi), so estimating with the posted dewalt specs (2000, 1450, 450) I am guessing the gear reductions are about 1:10, 1:14, 1:44.5. These are pretty close to the nothing but dewalt specs. I am not certain of my calculation so I am ordering a few different size sprockets in case that I am wrong.
Unread 30-01-2011, 16:31
de_ de_ is offline
AKA: Dave Edwards
I am pretty sure the exact 3 speed transmission and motor for the DC940 is listed on the robotwarehouse website. Now that I remember, I never took the transmission completely apart a year ago because I was afraid I couldn't figure out how to put it back together. Based on the overall ratios, the 3 planetary gear sets must each have different ratios.
