Go to Post 1. If I had a nickel for every time I heard "But we passed at XXXX regional" I would have retired a long time ago. - Al Skierkiewicz [more]
Unread 30-01-2011, 13:34
~piangere~ ~piangere~ is offline
FRC #1946
~piangere~ is an unknown quantity at this point
Deploying the minibot!!
I have a question about the last part of the game ,when deploying the minibot can the hostbot contact the tower directly , or should it send the robot from a distance???? if so what is the distant exactly ??
Unread 30-01-2011, 13:53
Duke461's Avatar
Duke461 Duke461 is offline
Boiler Strong.
AKA: Ben Carson
Duke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond repute
Re: Deploying the minibot!!
The Hostbot can make contact with the tower, but:
<G20> ROBOTS/HOSTBOTS may not contact their own TOWERS above the DEPLOYMENT LINE.
Violation: PENALTY for contact. TOWER is disabled if MINIBOT is DEPLOYED above the
DEPLOYMENT LINE.
The opposite of excellence is good enough.
2012-2013 President; 2011-2012 Vice President
2011-offseason FRC Student Drive Coach; 2010-11, 2011-2012 VEX Drive Coach
2011, 2010-offseason FRC Driver/Operator
2012, 2011-offseason, 2010-offseason FRC Human Player
Find me on: Facebook, Gmail, Twitter, Tumblr, Blogger/Blogspot
jamie_1930's Avatar
jamie_1930 jamie_1930 is offline
FRC #2228 (Cougartech)
Team Role: Student
jamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to behold
You should be touching the tower. If you increase the distance you are to the pole you will make it harder to deploy, and there is no rule against touching the tower so why not be right up against it?
Team 2228(FRC) - Drive Team Lead, Drive Coach, Mechanical Team
Team 3750(FTC) - Team Lead
2009
Team 2228(FRC) - Mechanical Team, Driver at RIT, and Hartford Regionals, and Drive coach at Ruckus
*Second Place at Ruckus
Team 3750(FTC) - Team Lead, and Drive coach at Clarkson Regional
*Second Place at Clarkson Regional
2008
Team 1930(FRC) - Worked on Mechanical, Electrical, and Programming.
Unread 30-01-2011, 13:54
Waffles's Avatar
Waffles Waffles is offline
Ship it!
AKA: Crystal Vongnaphone
FRC #1511 (Rolling Thunder)
Waffles has a brilliant futureWaffles has a brilliant futureWaffles has a brilliant futureWaffles has a brilliant futureWaffles has a brilliant futureWaffles has a brilliant futureWaffles has a brilliant futureWaffles has a brilliant futureWaffles has a brilliant futureWaffles has a brilliant futureWaffles has a brilliant future
Send a message via AIM to Waffles Send a message via MSN to Waffles
http://team2502.com/uploads/rules/3-Game.pdf
Manual. Use it.
Crystal Vongnaphone ... aka WAFFLES!
2010 Boston Regional Dean's List Finalist
FIRST Team 1511 Rolling Thunder
| Alumni | Leadership | Electrical | Media
Are you a Dean's list Finalist? Join our group!
Get the latest updates & important information on itsthedeanslist!
Unread 30-01-2011, 14:04
GaryVoshol's Avatar
Cogito ergo arbitro
Originally Posted by Waffles View Post
Don't use that version of the manual - it's 6 revisions out of date!
The most current version of the manual can always be found here: http://www.usfirst.org/roboticsprogr...nt.aspx?id=452
(since 2004)
Unread 30-01-2011, 14:09
Waffles's Avatar
Ship it!
Thanks.
Unread 07-02-2011, 21:58
mentarded mentarded is offline
mentarded is an unknown quantity at this point
Can the minibot touch the tower above the deployment line if it is still in contact with the hostbot? Meaning ...the minibot would drop from a higher level and then start below the deployment line as the hostbot disconnects? Does this refer to in future tense Read the manual, considering I have Read the manual.
Unread 07-02-2011, 22:23
Actually, refers to reading the Manual the right way.
The right way is to read the most current version, and read the Q&A to determine if your interpretation is correct.
In this case, No. The Minibot cannot break that deployment line while in contact with the Hostbot. See <G22>, as amended by Team Update #7.
Unread 07-02-2011, 22:35
Therefore, a radial angular descent, from a servo, while deploying the minibot would be acceptable as long as the minibot does not touch the tube... or are we to understand the tower implies the vertical plane of the base ? until the minibot is below the line? We need the gravitational force of a falling deployment arm to assist in engaging the minibot to the tower.
Unread 07-02-2011, 22:47
If the Minibot goes above the Deployment Line while the Hostbot is contacting the Minibot, the tower will be disabled. That is the rule. There is no "while the Hostbot is contacting the tower".
If you need that gravitational force, you will need to be able to apply it--all of it--while the Minibot remains in the 18" between the Deployment Line and the Base of the Tower.
Unread 07-02-2011, 22:57
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
I think this is your question - You approach the tower from the side. Your minibot deployment mechanism forms an arc, from the hostbot to tower. This arc allows the mnibot to be above the 18" deployment line. Your minibot does not touch the tower until it is below the 18 line.
My perception is that this is legal. You cannot touch the tower above the 18" line. The rule does not say you cannot break the plane that is formed by the 18" line. If it did, the only deployment option would be a straight horizontal launch to the bar.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 07-02-2011, 23:03
Chris, I think the Q&A disagrees with you.
http://forums.usfirst.org/showthread.php?t=16251
Unread 07-02-2011, 23:22
An arcing deployment system is what we are trying to achieve.
Deployment has multiple explanations, based on the method. In our case it is a gravity induced arc that will engage the bot. The question is when does the deployment line become effective, before the minibot is attached to the post? Or after the minibot is attached to the post?
The tower consists of the post and the base. The deployment line is on the post.
Is the horizontal plane and the vertical plane of the deployment line and tower base a defined zone of no entry unless we are beneath the deployment line?
"I've got vision and the rest of the world is wearing bifocals."
Butch Cassidy
Unread 07-02-2011, 23:27
nitneylion452's Avatar
AKA: Joe Lee
Butch Cassidy
Please see the Q&A EricH posted above.
Unread 07-02-2011, 23:29
I get it . Yes, no!
