Go to Post If there's one thing I've learned, it's that the robot is never truly finished. - Joseph Smith [more]
Unread 29-01-2011, 17:38
Peragore's Avatar
Peragore Peragore is offline
CEO of Black Magic
AKA: Philip Mulford
FRC #3373 (Team Robohawk)
Peragore is an unknown quantity at this point
Windriver Builder freezes halfway through
Hey,
For some reason, about 52% through the build command, it inexplicably fails and will not continue to build. Any advice?
Thanks for any help in advance.
Unread 30-01-2011, 13:05
taichichuan's Avatar
taichichuan taichichuan is offline
Software Mentor
AKA: Mike Anderson
FRC #0116 (Epsilon Delta)
taichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud of
Send a message via AIM to taichichuan
Re: Windriver Builder freezes halfway through
Can you copy and paste the build output from the build console view in the lower portion of the workbench window? It might help in diagnosing what's happening.
Mike
Unread 30-01-2011, 14:09
Peragore's Avatar
CEO of Black Magic
AKA: Philip Mulford
Thanks for the reply, but it started working. Apparently the windows firewall blocked it
while (life){
  frcObsession = true;
  obs.ProgramAndObsess();
if (!life) life = true;
