Go to Post Surely, we've seen enough new and interesting implementations of technology in FIRST that we won't keep limiting our imagination to the tried and true. - Madison [more]
Unread 30-01-2011, 15:06
takara159 takara159 is offline
FRC #3574
takara159 is an unknown quantity at this point
Smile Articulated ARM : Sensors / Programming
Fellow Programmers:
Looking for some guidance on how people are working with the articulated arm for this years competition in terms of motor control (Sensors) and programming it with Lab View.
Our team has come up with several different methods of tracking where the arm is in relation to itself:
Magnetic sensors, counting the number of magnetic variations as it relates to positions. (Not 100% clear on how to program this with Lab View)
Proximity Sensors, having the sensor look for changes in depth on a cog with multiple holes and using those as an indicator of position (There is no real good documentation that we have found on how to wire up or program the proximity sensor)
Potentiometer or Encoder: This seems to be the easiest route for a first year team as there is example code built into Lab View.
Thoughts ?
Thank you in advance
Unread 30-01-2011, 15:12
Joining the 900 Meme Team
FRC #0079
Re: Articulated ARM : Sensors / Programming
Potentiometers for arms (with limited rotation) are usually best. Encoders are good for things that spin a lot.
Unread 30-01-2011, 21:24
FRC #3574
Do you have any recommendations for Potentiometers ?
I didn't see any in the kit, I am assuming they aren't included.
Thanks
Unread 30-01-2011, 22:36
Kyle Fenton Kyle Fenton is offline
GET IT ON!!
FRC #0121 (Rhode Warrior)
Kyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud of
Send a message via AIM to Kyle Fenton
I would get a 10 turn potentiometer in or around the 10k range. Here is one example that my team used this year.
https://www.alliedelec.com/search/pr...px?SKU=9701865
Also you will need to order a plastic sprocket and a fitting for the shaft of the potentiometer.
Rhode Warriors
NAVSEA/Raytheon/URI/Middletown, Portsmouth, Tiverton, Mt. Hope HS
Quality Robots Since 1996
