Go to Post Also, after 3 years of FRC I finally hugged that Platypi! - That 281 Guy [more]
Unread 30-01-2011, 16:21
firstR00kie firstR00kie is offline
FRC #3611
firstR00kie is an unknown quantity at this point
"Limited" Wireless Access
Hey, we are a rookie team are having trouble with our wireless connection; whenever I try to connect to the radio, it says that access is limited and the light next to communication in the Driver Station stays red. I'm using my own laptop, not the classmate, and when I use a cable to connect to the cRIO it works fine. Anyone else have this problem or know how to fix it? Any help would be appreciated.
Unread 30-01-2011, 16:47
Trent B Trent B is offline
College Mentor
AKA: Trent Borman
no team (Surviving Grad School)
Trent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to behold
Send a message via AIM to Trent B Send a message via Yahoo to Trent B
Re: "Limited" Wireless Access
I am not sure how to solve your other issue (we are having a similar one), but a clarification on limited.
in windows if you have a network connection without internet access they define it as limited. Since the robot is supposed to be on a LAN without an internet connection this should be expected.
Former 2502 (Talon) Captain and 3928 (Neutrino) Mentor, currently teamless and attending Penn State for graduate school.
Have questions about Iowa State University or Penn State University? Feel free to email or PM me
Unread 30-01-2011, 18:41
In order to establish communication with the cRIO, the Driver Station program has to be on a computer with a matching IP address (10.36.11.5 for your team).
Unread 30-01-2011, 18:54
Coach#3536 Coach#3536 is offline
2015 Carver 2nd Alliance Captain
AKA: The Hemi
FRC #3536 (Electro Eagles)
Coach#3536 is an unknown quantity at this point
Hello Alan,
I have the same issue as listed above. The one difference is that I have checked addresses and everything now apprears to check out. The one thing that I wonder is what would make the communication be sparatic on the driver station if everything is correct?
Is there an area of the program.....say the watchdog not being present in the program that is causing the communication to drop??
Unread 31-01-2011, 21:08
FRC #3611
Ok, got it working!
You were both right, limited access is still there even while it works and the IP is 10.xx.yy.5 in the wireless adapter properties (I had a 6 instead of a 5 at the end).
Thanks for the help guys!
