Go to Post In my opinion, FIRST is better than a sport. - s_forbes [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 30-01-2011, 16:33
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
Re: Jaguar Speed Control Only Reaches 50% of Setpoint
Originally Posted by Mr. Lim View Post
Can you confirm that a P-Only control loop will only get you half-way to the setpoint?
I have some concerns that the speed control mode on the Jags is missing some important functionality.
If the P term doesn't accumulate in velocity control, it will go to 0 as it gets closer to the setpoint. This usually results in a P-only loop appearing stable, but only hitting about 50% of the setpoint.
A workaround is to have an I term that will get you all the way to the setpoint. However, I've heard elsewhere that the I term goes to zero as soon as the setpoint is attained, so as to prevent overshoot/wind-up. I can't confirm this 100%, but based on some initial testing I'm led to believe this is the case, as an I-only loop seems to hit the setpoint, then cuts out, only to accelerate up to the setpoint and cut out again.
Right now, we're using a P-only loop, setting the setpoint twice as high as we really want it. It's a sloppy workaround, but the best we've come across so far.
Yes, without an I coefficient, you can't expect to ever reach the setpoint; you get partway there, and then don't go any further.
I haven't tried an I-only loop.
If you're intent on using P only, what happens when you double your P coefficient? Is that the point where it starts to oscillate?
-- Marshal Horn
