Go to Post I suppose this would be a bad time to reveal that Q and LookingForward are the same robot person hybrid thing... - EricVanWyk [more]
Unread 30-01-2011, 13:21
de_ de_ is offline
AKA: Dave Edwards
FRC #1310 (Runnymede Robotics)
de_ is a jewel in the roughde_ is a jewel in the roughde_ is a jewel in the roughde_ is a jewel in the rough
Banebot 775 versus FP motor
Anyone have any good comparision data of the 775 running at 12v compared to the FP motor ?
Unread 30-01-2011, 13:39
bladetech932's Avatar
bladetech932 bladetech932 is offline
Programmer of awesome
AKA: Jon
FRC #0932 (Circuit Chargers)
bladetech932 is on a distinguished road
Re: Banebot 775 versus FP motor
Attached is the motor curves data sheet from the FIRST website.
hope it helps.
Expect the best, Prepare for the worst
Unread 30-01-2011, 13:59
hope it helps.
I believe the 12 volt RS775 data in that PDF is incorrect. See this thread.
...or this one.
Unread 30-01-2011, 16:28
AKA: Jon
yeah its 18v but the motor is still run at 12v, the motor running at 12v is what is in the data sheet
Unread 30-01-2011, 16:43
Vikesrock's Avatar
Vikesrock Vikesrock is online now
Team 2175 Founder
AKA: Kevin O'Connor
Yes, it appears this document has been updated. The initial motor curve sheet posted by FIRST used the wrong 775 specs.
Unread 30-01-2011, 16:49
AKA: Jon
Yes, it was updated on the 26th
Unread 30-01-2011, 16:55
Has anyone here measured the locked-rotor inductance for the RS775, or seen a spec for that anywhere?
If not, how about scope traces of the locked-rotor motor current when running with the Jag at low duty cycles (like say 20% or so).
