Go to Post If only CD had a "like" button. - BrendanB [more]
Unread 30-01-2011, 01:03
TD912 TD912 is offline
AKA: Chris Leung
FRC #1989 (Viking Robotics)
TD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud of
Mecanum control scheme?
We had a bit of an argument over what would be an efficient way to control a mecanum bot. I have realized many teams attempt compete with mecanum bots, but don't always take full advantage of their maneuverability.
Let's be clear: Please do not turn this into another mecanum vs. 6wd discussion, this is about controlling mecanum bots easily and efficiently.
I suggested a 2 joystick approach. This could either be 2 Logitech Attack joysticks, or a PS2-like gamepad.
The left joystick would move forward, backwards, and strafe, while the right joystick would control rotation.
I feel like this would give the maximum amount of control. It is somewhat similar to a first-person-shooter video game. However, a concern has been brought up about 2 joysticks being too complicated and unnecessary.
Another suggestion was to use only 1 joystick and have a "mecanum mode" switch, where the robot would drive like a 'regular' bot until a button is pressed. Enabling the button would then allow it to temporarily strafe, until the button is released.
This eliminates the need for 2 joysticks, but limits the movement of the robot to either strafing or rotating; it can never do both at once.
I feel this defeats the purpose of having a mecanum drive, as it is being looked at as a 'regular' drive with optional strafing ability.
Then there is also the option of getting a 3-axis joystick, but all of us seem to dislike that idea.
What do you guys think? Or do you have any other suggestions?
Zip-ties, hot glue, and duct tape.
2008 New York City Regional Champions - (41/555/1989)
2009 Brunswick Eruption 8 Finalists - (1989/56/1807)
2010 PARC XIII Champions - (25/341/1989)
Over The Bump
Unread 30-01-2011, 01:09
BigJ BigJ is online now
AKA: Josh P.
BigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond repute
Re: Mecanum control scheme suggestions?
We use the first scheme mentioned, a translation stick and a rotation stick.
You want to be able to translate and rotate simultaneously to "orbit" things.
Unread 30-01-2011, 01:26
There are a few different suggestions for driver interface here.
Unread 30-01-2011, 17:23
AKA: Chris Leung
Is "orbiting" like pivoting around a point? Similar to this video at 0:29?
The person who was suggesting the second control layout says we shouldn't ever have a need to rotate & strafe simultaneously.
However, I believe having 2 joysticks is worth the slight increase in complexity, as it allows for greater maneuverability (which is why we chose mecanum in the first place!)
Over The Bump
Unread 30-01-2011, 17:44
AKA: Josh P.
Yeah, that's exactly what I meant, I should have described it more.
Unread 01-02-2011, 08:59
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
Re: Mecanum control scheme?
.....Then there is also the option of getting a 3-axis joystick, but all of us seem to dislike that idea........
Why? We used the Logitech 3d last year, liked it.
Unread 03-02-2011, 13:52
couvillion couvillion is offline
FRC #1818
couvillion is an unknown quantity at this point
I haven't found a rule against it yet so I am planning to use the first joystick to control translation, and the take apart a second joystick to create a dial that controls facing.
Unread 03-02-2011, 13:57
How are you going to process the output from this dial? e.g. Are you going to extract the angle and use that to create a setpoint for a closed-loop control with gyro angle as the process variable... or something else?
Unread 03-02-2011, 14:43
FRC #1818
That is the basic plan. I think some of that is already supported in LabView Mecanum VI. A knob perhaps with stops for face goal, face feeding station seems to be the appropriate level of abstraction for this game.
Certainly a self centering joystick can't control facing and the driver doesn't need to worry about about turning speed he needs to worry about facing so giving him a control of rotation speed simply is making him do the control loop stuff in his head.
Unread 03-02-2011, 15:04
The functionality you seek is not part of the library support. The library support for holonomic is limited to using the gyro for field-centric control, not for angular-position seeking and holding.
Unread 03-02-2011, 15:39
FRC #1818
Been thinking about PID controllers for a while now. Hope I get it right.
Unread 03-02-2011, 15:58
This may help.
Unread 04-02-2011, 18:30
fhsroboticsteam fhsroboticsteam is offline
FRC #3414
fhsroboticsteam is an unknown quantity at this point
This would be the inexpensive route that our team took
Buy a used original Xbox controller on ebay or craigslist (very cheap), or request a donation from a team member.
Chop the end and solder it to a male end of a usb cable. (yes the original xbox controllers are usb)
Download the drivers
http://www.redcl0ud.com/xbcd.html
In labview the axes from the controller will come out as follows
Axis 1: Left thumbstick X
Axis 2: Left thumbstick Y
Axis 4: Right thumbstick X
Axis 5: Right thumbstick Y
you will also get an extra 12 buttons along with your 4 axises
We used Axis 1 and 2 to go forward, backward, left and right
and axis 4 to rotate.
Hope this helped.
Unread 05-02-2011, 16:42
AKA: Chris Leung
Yeah, we're likely going to go with a USB gamepad, similar to this one:
http://www.newegg.com/Product/Produc...-042-_-Product
There's also two models from Logitech that are similar (or the same?) to the one used in FTC, and they're only around $10-25:
http://www.amazon.com/gp/product/B00...ce-full-site=1
Over The Bump
