Go to Post FIRST already has 494 Martians, plus 70 more. - GaryVoshol [more]
Unread 30-01-2011, 18:19
Re: Analog voltage
Originally Posted by bladetech932 View Post
i was asking about analog inputs they dont have pre-written VIs for
There's a complete set of them.
WPI Robotics Library >> IO >> AnalogChannel
The Analog Get Voltage function is probably the one you'll be using. As the name implies, it returns the voltage present on the Analog Input pin.
