Go to Post Inspect every connection after every match. Use your eyes, ears and nose. - Al Skierkiewicz [more]
Unread 30-01-2011, 19:17
sjspry sjspry is offline
FRC #1984
sjspry has a spectacular aura aboutsjspry has a spectacular aura aboutsjspry has a spectacular aura about
Re: Receiving UDP packets on the CRIO
A ServerSocketConnection is TCP, not UDP. You'd be wanting DatagramConnection, which is UDP. Open with
Connector.open("datagram://:<port>");
for incoming, and
Connector.open("datagram://<ip>:<port>");
for outgoing (I always thought UDP sockets were bidirectional, but I guess J2ME handles it somewhat differently).
Unread 31-01-2011, 07:03
John Heden John Heden is offline
FRC #1073
John Heden is an unknown quantity at this point
Greetings,
I'm attaching a working CRIO C++ example function that we managed to get working the other day. I wish I could help in Java but perhaps this example might help. There is some dialog on this on another thread around what we can/can’t do with this new UDP functionality.
John
Related thread:
http://www.chiefdelphi.com/forums/sh...&highlight=UDP
Unread 31-01-2011, 08:47
alexhenning alexhenning is offline
WPILib Developer
FRC #0348
alexhenning will become famous soon enough
I had tried datagram before, unfortunately, when I run it I get:
[frcrun] [cRIO] javax.microedition.io.ConnectionNotFoundException: The 'datagram' protocol does not exist
[frcrun] [cRIO] at javax.microedition.io.Connector.open(245)
[frcrun] [cRIO] at javax.microedition.io.Connector.open(193)
[frcrun] [cRIO] at javax.microedition.io.Connector.open(177)
[frcrun] [cRIO] at org.usfirst.frc348.BreakoutBox.<init>(BreakoutBox. java:29)
[frcrun] [cRIO] at org.usfirst.frc348.JagBot.<init>(JagBot.java:24)
[frcrun] [cRIO] in virtual method #11 of com.sun.squawk.Klass(bci=53)
[frcrun] [cRIO] at com.sun.squawk.imp.MIDletMainWrapper.main(99)
[frcrun] [cRIO] in virtual method #95 of com.sun.squawk.Klass(bci=25)
[frcrun] [cRIO] at com.sun.squawk.Isolate.run(1506)
[frcrun] [cRIO] at java.lang.Thread.run(231)
[frcrun] [cRIO] in virtual method #47 of com.sun.squawk.VMThread(bci=42)
[frcrun] [cRIO] in static method #3 of com.sun.squawk.VM(bci=6)
Is there something different about the version of J2ME running on the CRIO?
Unread 31-01-2011, 13:03
derekwhite's Avatar
derekwhite derekwhite is offline
Java Virtual Machine Hacker
no team (FIRST@Oracle)
derekwhite is on a distinguished road
Which protocols are supported aren't standardized in CLDC. Java on the cRIO supports socket:, serversocket:, and file: protocols currently. Unfortunately it doesn't support datagrams yet.
Unread 31-01-2011, 15:23
WPILib Developer
FRC #0348
Thanks for the info. That's very very annoying, do you know if there are any plans to add support for it. We were going to take advantage of the UDP ports for a custom dashboard and breakout box, but we'd rather stay in java.
Unread 31-01-2011, 21:13
FRC #1984
If you read team update #5 it mentions a TCP port you can take advantage of, it's currently what I'm using. There's really no good reason to be using UDP, seeing as communications are so close (it just ends up making things more complicated, but whatever).
Oh, port should be 1180, just remembered.
Unread 01-02-2011, 13:51
Wouldn't that be a better reason to use UDP? If there's less of a chance of dropped packets, why bother with the added overhead of TCP?
Unread 01-02-2011, 18:51
FRC #1984
Because the "overhead" of TCP is barely noticeable (the information density is ~94%, with ~6% left for headers) and really only comes into play when you have a noisy connection, where packets would be missed and therefore resent, and during the initiation of a connection, which you do once. Dropped packets are a non-issue, as well, and wouldn't affect TCP's performance. It happens, but very rarely (comparatively) and in everything I've experienced it's rarely anything but hardware problem.
Besides apparently not being able to use UDP, TCP is generally easier to use, as a stream, than to have to fit everything into a fixed datagram and then unpack it (this is more of a personal choice, though). The only benefit of UDP will be if you are sending time sensitive information, otherwise I see no reason why it would be chosen to use.
It doesn't matter either way. You can do some time tests with TCP vs UDP, if you want.
Unread 03-02-2011, 20:50
WPILib Developer
FRC #0348
I was planning on using the camera too, which according to the update is used by the camera. Also, I control data is time sensitive, so UDP seemed sensible.
Unread 24-02-2014, 14:13
AlexBrinister AlexBrinister is offline
AKA: Alex Brinister
FRC #1768 (RoboChiefs)
AlexBrinister will become famous soon enough
I was looking at the WPILib/CLDC very carefully recently and I noticed that there is a package called com.sun.cldc.jna that specifies several classes to allow for calling native functions from Java. I was wondering if one could make use of vxWorks UDP functions and implement a UDP communication class using native vxWorks calls. I notice that this is what WPILib essentially does with functions like FRC_NetworkCommunication_JaguarCANDriver_sendMessa ge and FRC_NetworkCommunication_JaguarCANDriver_receiveMe ssage. It appears that this is almost like extern'ing in C/C++.
Alex Brinister
Unread 25-02-2014, 13:50
NotInControl NotInControl is offline
Controls Engineer
AKA: Kevin
FRC #2168 (Aluminum Falcons)
NotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond repute
This might be obsolete, as next year Java teams are no longer constrained to Java ME, and can use the full power of Java SE (which supports both TCP and UDP) on the RoboRio.
Don't think it is fruitful to attempt to add functionality to the current system since it will be phased out next season.
Hope this helps,
Kevin
Controls Engineer, Team 2168 - The Aluminum Falcons
[2016 Season] - World Championship Controls Award, District Controls Award, 3rd BlueBanner
-World Championship- #45 seed in Quals, World Championship Innovation in Controls Award - Curie
-NE Championship- #26 seed in Quals, winner(195,125,2168)
[2015 Season] - NE Championship Controls Award, 2nd Blue Banner
-NE Championship- #26 seed in Quals, NE Championship Innovation in Controls Award
-MA District Event- #17 seed in Quals, Winner(2168,3718,3146)
[2014 Season] - NE Championship Controls Award & Semi-finalists, District Controls Award, Creativity Award, & Finalists
-NE Championship- #36 seed in Quals, SemiFinalist(228,2168,3525), NE Championship Innovation in Controls Award
-RI District Event- #7 seed in Quals, Finalist(1519,2168,5163), Innovation in Controls Award
-Groton District Event- #9 seed in Quals, QuarterFinalist(2168, 125, 5112), Creativity Award
[2013 Season] - WPI Regional Winner - 1st Blue Banner
Unread 25-02-2014, 21:02
AKA: Alex Brinister
Agreed. Also the method I was suggesting doesn't work because to implement sockets in C, you need special types such as sockaddr, sockaddr_in and others and with the native library functions, you can only access functions from shared objects. It is certainly nice to hear they are replacing ME with SE!
Alex Brinister
