Go to Post I've got it! INFLATABLE clown fish!!!! - dlavery [more]
Unread 30-01-2011, 19:42
Must Be Drama Must Be Drama is offline
Must Be Drama is an unknown quantity at this point
Line Tracking VI. drives in half a circle...?
it pretty much really reflects it self... how to fix this please i need help
Unread 30-01-2011, 20:47
Ethan Spitz Ethan Spitz is offline
President
FRC #3637 (The Daleks)
Ethan Spitz is an unknown quantity at this point
Re: Line Tracking VI. drives in half a circle...?
Can you post your code? I can't really help without seeing what you have.
Ethan
www.team3637.com FIRST team 3637's Website: The Daleks
Unread 30-01-2011, 21:36
The default code will drive in a half circle if it is placed on the wrong side of the line and then auto is run. In general, I believe it is best to have one of the sensors on the line, and even better, a known starting condition.
Greg McKaskle
Unread 30-01-2011, 22:01
Greg McKaskle
can you explain wrong side of line?
Unread 30-01-2011, 22:09
j.cole j.cole is offline
FRC #0379
j.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud of
I'd say check your IR sensor placement and make sure that its not a hardware problem before you blame the code
It's not normally a good idea to give a programmer a drill but rules are made to be broken.
Unread 30-01-2011, 22:50
If you have told the robot to track the left edge of a line but you've placed it so the sensors are to the right of the line, it will turn right looking for the line and not find it.
Unread 31-01-2011, 18:28
okay il say our set up... we have last years robot we attached the sensers to the front. our previous robot has mech wheels.. i watched the frcmastery video but it doesnt help us any thing else could i say so some one could help us?
Unread 31-01-2011, 18:30
President
well if you don't think its related to sensor trimming or hardware then I highly suggest rewriting your coding.
Unread 31-01-2011, 18:40
but this is the default code... i dont understand why is it not attempting..
Unread 31-01-2011, 18:43
President
Did you open up your sensors as IR1 IR2 and IR3? in begin.vi?
Unread 31-01-2011, 18:46
yes sir
Unread 31-01-2011, 18:47
President
yes sir
Are the sensors plugged into the correct DIO ports? And correct order or LO and DO?
Unread 01-02-2011, 13:15
IisMathwizard's Avatar
IisMathwizard IisMathwizard is offline
Programming Mentor
AKA: Mathwizard
FRC #1248 (Titanium Allies)
IisMathwizard is an unknown quantity at this point
Possible solution
The thing our team did was decide on a setup for the sensors....
It looks something like this:
After deciding on this setup we came up with a boolean setup that would, based on which lights were coming back true, turn the robot. We also made the sensory aspect of this custom code activate by pressing and holding button one. When this happened, the robot would no longer recieve x-values from the controller but recieve x-values from the code. It still allowed for y-axis values from the contoller.
jRIO 2013 Project
