Go to Post I can neither confirm nor deny that I've worked on alot of pretty cool stuff. - Gary Dillard [more]
Unread 30-01-2011, 18:10
tomy tomy is offline
FRC #3038 (I.C.E. Robotics)
tomy has a spectacular aura abouttomy has a spectacular aura about
Gyro + accelometer C++ Programing
this year we are finally going to use the gyro and accelometer, both of them are hocked up right but neither of them are working.
the gyro is hooked up to crio module 1 slot 1
and the accelometer is hooked up to the I2C port.
we tried to program them but neither are working
anyone got some example code
p.s. sorry if there is another post about this i running late for a meeting and needed to post it quickly before i forgot
Unread 30-01-2011, 19:24
basicxman basicxman is offline
Emily Horsman
FRC #2200 (MMRambotics)
basicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant future
Send a message via AIM to basicxman Send a message via MSN to basicxman Send a message via Yahoo to basicxman
Re: Gyro + accelometer C++ Programing
Could you please post the source code you are trying?
Unread 30-01-2011, 19:39
I don't have the computer now but for the gyro we did
gyro.reset
        gyro.get angle()
Is there anything special you have to do to see it the driver station?
Unread 30-01-2011, 19:41
Emily Horsman
gyro.reset
        gyro.get angle()
That code is incorrect,
gyro.Reset();
gyro.GetAngle();
Unread 30-01-2011, 19:56
Like I said I dont have the computer...
Unread 30-01-2011, 20:00
Emily Horsman
DriverStationLCD *display = DriverStationLCD::GetInstance();
char text[255];
sprintf(text, "Gyro Value: %f", gyro.GetAngle());
display->Clear();
display->PrintfLine(DriverStationLCD::kUser_Line1, text);
display->UpdateLCD();
Or if you mean the display on the Dashboard, take a look at the DashboardData sender in some of the example projects (such as Vision tracking).
Unread 30-01-2011, 20:02
Only call Reset() when you want to reset the gyro to its initial state. If you do it every time you try to read GetAngle(), you will always read zero.
Unread 30-01-2011, 20:14
Thanks ala
Will it automatically show up on the driver station (the compus thingie)
Unread 30-01-2011, 20:21
Emily Horsman
Thanks ala
That's the dashboard, and no it won't. Take a look at the example project DashboardDataExample.
Unread 30-01-2011, 20:27
what about the accelometer we have it pluged into the I2C Port in our programing i think we did something like this
acc.(I2C);
and it did not work
Unread 30-01-2011, 20:29
Emily Horsman
acc.(I2C);
and it did not work
That shouldn't have compiled, here are the available functions for the ADXL345 accelerometer: http://mmrambotics.ca/wpilib/class_a...45___i2_c.html
You are initializing these objects too correct? Please post full source code when you can, it will be much easier for us to help you.
Unread 30-01-2011, 20:35
tommarow around 4 central time i will post my code here
