Go to Post Save the frustration for build season. :p - Brian C [more]
View Poll Results: Will we see a mini bot go up in less then 2 secs
yes 175 70.00%
no 75 30.00%
Voters: 250. You may not vote on this poll
Unread 30-01-2011, 18:02
nuggetsyl's Avatar
nuggetsyl nuggetsyl is offline
FRC #0025
nuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond repute
under 2 sec Mini bot
I am starting to think is possible to get a mini bot up in under 2 secs.
00,12Championship winner
03,06,08 Championship finalist
02A,03C,06N,08C,11N,12G Division winner
00,03,06,07,08,10,12 NJ / MAR winner
11 VCU winner
06,10 Las Vegas winner
12 MAR Mt Olive
red is for team 348
Unread 30-01-2011, 18:04
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Re: under 2 sec Mini bot
I think it's been proven that a mini-bot can climb the pole in less than two seconds.
I wonder how many people can figure out how to do it?
-Dustin Benedict
Unread 30-01-2011, 18:07
BJC's Avatar
BJC BJC is offline
Simplicity is Complicated!
AKA: Bryan Culver
FRC #0033 (The Killer Bees)
BJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond repute
Today while at work I was doing some math on my phone and I got the theoretical time very nearly below 1 second.
robot robot robot? Robot. Robot? Robot!
-----------------Team 33------------------
Unread 30-01-2011, 18:08
itsalka's Avatar
itsalka itsalka is offline
FRC #3070 (Pronto)
itsalka is an unknown quantity at this point
How are you getting your minibots to do that?
So far we've gotten the bot up in 10 seconds, but we're running into difficulties for making it go faster with our tetrix wheel (not the best traction), and messing around with the gear ratios, and just finding where to distribute weight.
What kinds of designs are you guys using?
Unread 30-01-2011, 18:09
Chris27's Avatar
Chris27 Chris27 is offline
AKA: Chris Freeman
FRC #1625 (Winnovation)
Chris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant future
Yes.
Proof by example
http://www.chiefdelphi.com/forums/sh...ad.php?t=90114
Q.E.D.
(unless you are including the start of deployment as well?)
Unread 30-01-2011, 18:24
BJC's Avatar
BJC BJC is offline
AKA: Bryan Culver
I won't tell you exactly how. But, concerning weight distribution ideally your weight is pushing your drive wheel(s) into the pole, concerning gear ratios find the top of the power curve and eliminate extra gearing as each stage adds inefficiency, concerning tetrix wheel traction slit some surgical tubing down the middle and put it around the wheel with PVC glue to secure it (just an idea, haven’t tried it).
Good Luck
Unread 30-01-2011, 18:29
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
It's all in the design.
1. Minimize weight.
2. Increase efficiency (eliminate gears)
3. Maximize power through gear ratio and wheel size choice.
4. Profit!
There are also some other games you can play to increase the power of the system (legally).
Unread 30-01-2011, 20:09
foozie's Avatar
foozie foozie is offline
AKA: Matt Howard
FRC #1124 (The ÜberBots)
Team Role: Webmaster
foozie is an unknown quantity at this point
Originally Posted by Chris27 View Post
Yes.
Proof by example
Q.E.D.
Remember that that video is without a battery. Is there any minibot who has actually climbed the 8 ft with a battery in less than 2 seconds?
Unread 30-01-2011, 20:11
Swampdude's Avatar
Swampdude Swampdude is offline
AKA: Dan Quiggle
FRC #0179 (Children of the Swamp)
Swampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond repute
Those of us who can/have done it aren't likely to show anything until competition, otherwise everyone will be doing it. Even then keeping them covered in the pit might be common. It's so easy to reconfigure these tetrix kits.
www.179swampthing.org
Unread 30-01-2011, 20:21
Garten Haeska's Avatar
Garten Haeska Garten Haeska is offline
AKA: Garty
FRC #2861 (Infinity's End)
Garten Haeska has a spectacular aura aboutGarten Haeska has a spectacular aura about
my mini bot goes up in 4-5 seconds and it only has one set of wheels powered and i plan to put it on both sets
Alpha Beta's Avatar
Alpha Beta Alpha Beta is offline
Strategy, Scouting, and LabVIEW
AKA: Mr. Aaron Bailey
FRC #1986 (Team Titanium)
Alpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond repute
I agree. Has anyone considered having a 3 second bot for Thursday and Friday, and saving the sub-2 second bot for Saturday as a secret weapon?
Regional Wins: 2016(KC), 2015(St. Louis, Queen City), 2014(Central Illinois, KC), 2013(Hub City, KC, Oklahoma City), 2012(KC, St. Louis), 2011(Colorado), 2010(North Star)
Regional Chairman's Award: 2014(Central Illinois), 2009(10,000 Lakes)
Engineering Inspiration: 2016(Smoky Mountain), 2012(Kansas City), 2011(Denver)
Dean's List Finalist 2016(Jacob S), 2014(Cameron L), 2013(Jay U), 2012(Laura S), 2011(Dominic A), 2010(Collin R)
Woodie Flowers Finalist 2013 (Aaron Bailey)
Championships: Sub-Division Champion (2016), Finalist (2013, 2010), Semifinalist (2014), Quaterfinalist (2015, 2012, 2011)
Other Official Awards: Gracious Professionalism (2013) Entrepreneurship (2013), Quality (2015, 2015, 2013), Engineering Excellence (Champs 2013, 2012), Website (2011), Industrial Design (Archimedes/Tesla 2016, 2016, 2015, Newton 2014, 2013, 2011), Innovation in Control (2014, Champs 2010, 2010, 2008, 2008), Imagery (2009), Regional Finalist (2016, 2015, 2008)
Unread 30-01-2011, 20:25
Cyberphil's Avatar
Cyberphil Cyberphil is offline
That Guy
AKA: Phil
FRC #0103 (Cybersonics)
Cyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud of
Send a message via AIM to Cyberphil
That is interesting. But even then, if it uses the same tetrix parts, and if another team has the parts needed, I think they could create it over lunch or something. I think it is a good idea to keep your design concealed, but you can keep it concealed even when you are using it in competition.
MagiChau's Avatar
MagiChau MagiChau is offline
AKA: Michael Chau
FRC #0085 (B.O.B. (Built on Brains))
MagiChau is just really niceMagiChau is just really niceMagiChau is just really niceMagiChau is just really nice
I would say this is a bad plan since you are doing an unnecessary limit. Do not purposely weaken your team's capability to effectively complete the challenge. Do your best at qualifications so you can use the "secret weapon" during eliminations.
EDIT: after reading Cyperphil's post, if you want to really hide then cover the minibot with polycarbonate since its allowed.
Unread 30-01-2011, 20:26
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Wait a minute here... So teams have already build (or at least prototyped) their minibots already? Our team only has the CAD and a prototype made with servos. We are behind.
edit: our design is so crazy that I doubt that any team can fabricate the deployment system and the minibot in the 2 day period.
Unread 30-01-2011, 20:29
MagiChau's Avatar
AKA: Michael Chau
My team started prototyping the day we got the FTC kit. We went through I think at least 4-5 different prototypes already. Forgot if our current minibot is going to be final design.
