Go to Post Tom didn't need the t-shirt to tell us [that he is a NERD] :D - Peter Matteson [more]
Unread 31-10-2002, 09:54
f22flyboy's Avatar
f22flyboy f22flyboy is offline
Distributor of Mayhem
#0540 (Rhythmic Disturbance)
f22flyboy will become famous soon enoughf22flyboy will become famous soon enough
12V Tether pinout
Does anyone know the pin-out for the 12V OI tether. We're thinking about wiring up a backshell so we can run the OI off of a large 12V battery. I know this is a little unsafe for the OI, but if it works it would be great. Anyone?
Godwin Robotics Association- Rhythmic Disturbance
Team 540 Forums
FIRST Look... FIRST Shot... FIRST Kill.
Unread 31-10-2002, 10:23
AdamT's Avatar
AdamT AdamT is offline
#0401
AdamT is on a distinguished road
Please just post in one forum if you have a question....
We just built a separate battery pack with "D" batteries and used the standard power input...
~Adam
Unread 31-10-2002, 11:32
Jnadke Jnadke is offline
Go Badgers!
#0093
Jnadke is on a distinguished road
Send a message via ICQ to Jnadke Send a message via AIM to Jnadke Send a message via Yahoo to Jnadke
Our team did this last year with some of the 12V rechargable (lead-acid) batteries...
Unfortunately I don't have the circuit schematic for it.
It shouldn't be that difficult though. It's just a simple voltage and current divider. Ratshack should sell connectors needed to plug into the OI's wall transformer input. The transformer brick should say what you need to output.
Ours was a little more complex. It had leds that dimmed as the voltage dropped from 13.5V to 8V. The transformer I believe puts out 7 or 7.5V... I could be wrong though.
The best moments of our lives fall in two categories: those that did happen and those that did not.
Unread 31-10-2002, 12:03
f22flyboy's Avatar
Thanks but we want to use the tether connection and leave the OI power input open for undisclosed reasons...
Innovation First doesn't have anything on power pinouts, anyone know who would?
Team 540 Forums
Unread 31-10-2002, 17:04
evulish's Avatar
evulish evulish is offline
1010100
AKA: Grant Harding
#0084 (WATTNESS (bot: Chuck))
evulish is just really niceevulish is just really niceevulish is just really niceevulish is just really nice
Send a message via AIM to evulish
Undisclosed reasons, ehh? *Mission Impossible theme plays*
I'm a professional web developer. I'm good with PHP, Perl, Java/JSP, some RoR, XML, Javascript (AJAX as well), (x)HTML, CSS, etc.. Validated code is good; fully cross-browser code is better (you comply to your users and the software they use, not the other way around. Sorry!)
Unread 31-10-2002, 19:02
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
Do you mean tether or competition? The tether port is 100% undocumented; they don't even say if it's RS-232 or something else. As for the competition port, which is probably more what you're looking for, is a little better, but not much.
Finally, I wouldn't be so sure that the tether is 12V. After all, the wall plug is only 9V.
Unread 31-10-2002, 20:06
Go Badgers!
#0093
What else would you use the power input port for???? Its only function is to input power.
You could probabaly get out the multimeter/voltmeter and start testing pins in the robot controller.
But, yeah, the Tether port is currently undocumented. It is a proprietary port, it has no certain specification. I wouldn't be surprised if it modeled an RS 232/242 port and just used one of the lines as a positive line.
Unread 01-11-2002, 10:03
f22flyboy's Avatar
thanks
So the only way is the hard way
I know the tether is 12V, what is the competitition port?
This is just out of curiosity, its taken up by the different channel adapter
Team 540 Forums
Unread 01-11-2002, 10:05
f22flyboy's Avatar
this thread will self-destruct in 5... 4... 3... 2... 1... *poof*
hehehe
Team 540 Forums
Unread 01-11-2002, 14:34
Go Badgers!
#0093
The competition port provides power to the robot controller as well. It is also capable of changing the OI channels and such.
However, you have the same problem. No documentation for the power pins.
Unread 01-11-2002, 14:51
f22flyboy's Avatar
I meant what is (the voltage of) the competition port
Team 540 Forums
Entanglement at Bash Rick Rules/Strategy 31 06-11-2002 21:30
tether after a match archiver 2001 9 24-06-2002 02:09
Portable 12V Power Supplies? archiver 2000 2 24-06-2002 00:19
Need pinout for tether adaptor archiver 1999 4 23-06-2002 21:55
