#8
Re: cRio Kernel Error/Reboots
Good news! It turns out it was a code problem, and the cRIO is fine.
The programmers were using the "FRC Sample Simple C Template" in Wind River as the default program, which we found out, the hard way, doesn't work. We're not sure why it's still included, even in fresh installs of Wind River/WPIlib. After formatting/re-imaging the cRIO again, we created and compiled a new project using the "FRC Simple Robot Template" and it worked perfectly. Also, in reading the "crio-frc_Operating_Instructions" PDF published by NI- "The NO APP switch does not affect C/C++ startup applications. You can use the Undeploy option in Wind River Workbench to disable a C/C++ application." ...which explains why it would continue to reboot while toggled. Everything is back to normal now. Thank you all! |
