Go to Post I have always been of the opinion that if the mechanicals are making noise they are trying to talk to you. - Al Skierkiewicz [more]
Unread 28-01-2011, 16:44
E2207 E2207 is offline
FRC #2207
E2207 is an unknown quantity at this point
Minibot Questions
Instead of making a new post for each question that was about the same mechanical component, I decided to make one post for all.
1) Can we use a clevis and control horn like the ones used in RC Airplanes to Open/Close the hinge mechanism to hold the minibot to the pole?
2) Since coiled metal springs are not allowed on the minibot (http://forums.usfirst.org/showthread.php?t=16517), and our team was planning to use compression springs to keep the "jaws" open until the minibot reached the pole, what substitution with surgical tubing could we use to keep the "jaws" open until the minibot reaches the pole.
3)Could we use polycarbonate pulleys for our closing plunger mechanism. They won't be contributing to any vertical movement, only to guide cable so they can pull the "jaws" close.
Unread 28-01-2011, 17:10
big1boom big1boom is offline
Chains=Fun
FRC #2022 (Titan Robotics)
big1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of light
Re: Minibot Questions
1) No, unless you make it yourself out of raw aluminum sheet. <R92-H>
2) You can make your own compression spring by taking a piece of polycarbonate, and simply bending it. <R92-F>
3) My first assumption is that polycarbonate pulleys are illegal, but I would suggest a Q&A on this one.
Unread 28-01-2011, 17:18
EricH EricH is online now
GDC isn't saying anything about form polycarb can take, other than a very broad "Polycarb is legal, and there are no restrictions on form" in http://forums.usfirst.org/showthread.php?t=16317
Unread 28-01-2011, 17:24
Henry Williams's Avatar
Henry Williams Henry Williams is offline
Vice President Team 461
Henry Williams is on a distinguished road
I'm pretty sure for the poly pulleys you would have to make your own for it to be leagal, however I am not sure enough that you should give up, I agree with the suggestion to Q&A that.
"Good enough will never win world." Ben "Duke" Carson
Unread 28-01-2011, 17:25
FRC #2207
Won't polycarbonate snap if it's bent so far?
Would a steel cable be considered legal?
Unread 28-01-2011, 17:29
Not if you do it right. Not being entirely certain of the method there, I'd say to find 1714 (or Chris is me) and ask them.
Steel cable: Not legal on the Minbot. You can use non-metallic rope or cord.
Henry, check the Q&A I linked to again.
Unread 28-01-2011, 17:37
Oh,okay sorry about that then.
Unread 28-01-2011, 20:22
FRC #2207
Another question that goes off topic from here.
Would it be illegal to use a jaw and cone clutch for our minibot mechanism? It would be connected to one of the motors the main drive OR just another motor we have running and propel the launching mechanism forward until a limit switch stops it.
Unread 30-01-2011, 21:34
As far as bending polycarb goes, it helps if you heat it first. We have an electric heater for just that purpose but you can also get the job done with a Heat gun if you're careful. But as you bend it (especially past 90 degrees) the material gets thinner and slightly more brittle (because you are actually stretching it) so it does have its limits. We had to get pretty good at this for our minibot
Unread 30-01-2011, 23:21
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
I don't think that would be legal, unless you could built it out of the allowed materials.
Unread 30-01-2011, 23:24
Only if you can construct one using the allowed materials in R92 and you have two or less Tetrix motors.
Unread 31-01-2011, 12:52
UnderAverageJoe UnderAverageJoe is offline
FRC #2883
UnderAverageJoe is an unknown quantity at this point
does anyone know what we can do to get the minbot down from the top of the pole? can we shake it? and we bring large extensions to get it down?
Unread 31-01-2011, 13:03
JB987 JB987 is offline
AKA: Joe Barry
FRC #0987 (HIGH ROLLERS)
JB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond repute
No specific prohibition against shaking the pole yet from GDC but Update #6 specifically prohibits use of any mechanism (stick, etc) from being used to retreive your minibot...
Unread 31-01-2011, 13:08
kbrowncny's Avatar
kbrowncny kbrowncny is offline
Mechanical Engineering Mentor
AKA: Kevin Brown
FRC #2168 (Aluminium Falcons)
kbrowncny is an unknown quantity at this point
How about threaded Aluminum rod. Is that permitted for use on the minibot?
Unread 31-01-2011, 13:13
Modified by TU #6
<G59> TEAMS must retrieve MINIBOTS from the TOWER quickly and safely without special equipment and while standing on the floor after each MATCH. Violation: The FIELD crew will retrieve the MINIBOT. A second violation may result in a YELLOW CARD.
It is expected that a MINIBOT will be able to be retrieved from the TOWER in less than 1 minute. If the FIELD crew has to retrieve the MINIBOT, they are not responsible for incurred damage to the MINIBOT. If a MINIBOT is deemed dangerous (i.e. in its design, or in the way the TEAM retrievese it from the TOWER), the Referee may issue a YELLOW CARD to the TEAM associated with the MINIBOT.
As to threaded rod, only if you can make it from...
H. Raw aluminum sheet, 90° angle, u-channel, tube, bar, that is not sold in pre-perforated or pre-punched form.
