Go to Post Do I think the bar is too high? I think impossible dreams and lofty goals are a key part of FIRST; the "top" being extremely far away only pushes people farther. - Chris is me [more]
Unread 30-01-2011, 21:37
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Any Team Using A Timer?
Any of you guys using the timer to make sure that the driver does not "jump the gun" with the minibot deployment? Now the minibot scoring will ultimately come down to the milliseconds. My only worry with this is that the software might not allow the driver to deploy on time. If I allow the minibot to be deployed a little earlier, it defeats the purpose of the timer in the first place; the driver might jump the gun.
Unread 30-01-2011, 21:58
mwtidd's Avatar
mwtidd mwtidd is offline
AKA: mike
FRC #0319 (Big Bad Bob)
Re: Any Team Using A Timer?
One thing to note is the robots perception of time, and the actual field time tends to differ. Trying to get it as exact as you are inferring will most likely be difficult. I think in the end the driver's perception of match time will be better than the robots. Rather than putting it on a timer, consider using a color sensor or camera to watch the color on the tower base and use that as the indicator.
Unread 30-01-2011, 22:01
MagiChau's Avatar
MagiChau MagiChau is offline
AKA: Michael Chau
FRC #0085 (B.O.B. (Built on Brains))
MagiChau is just really niceMagiChau is just really niceMagiChau is just really niceMagiChau is just really nice
I heard that sometimes the total match time varies. This is going to throw off your onboard timer. I would rather have the drivers train than program this feature.
Unread 30-01-2011, 22:04
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
My initial choice was to use a camera, but I then realized that due to the configuration of the robot and the chassis, it would be very hard for the camera to actually see the base of the towers. Essentially, no one had taken a serious consideration of that idea when I proposed it several times during the first few days after kickoff... So even the sensors are second rate components for the team. I find it very hard to incorporate the lintrackers to our current chassis...
Unread 30-01-2011, 22:07
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
The onboard timer is not tied directly to the FMS, but it counts beginning with the first enabled packet, which is pretty close. You will probably be more accurate than a human, and your match time will probably lag about 100ms max or so behind FMS. You could compensate for this or leave it, your choice. Still, that's barely in the range of human perception, so you would probably have an advantage by implementing it in software (although it would probably only be about 1/10th of a second or so)
Kettering Motorsports
Unread 30-01-2011, 22:20
Dustin Shadbolt's Avatar
Dustin Shadbolt Dustin Shadbolt is offline
In a server room somewhere...
AKA: Dustin Shadbolt
FRC #1555 (Team PULSE)
Dustin Shadbolt is on a distinguished road
I would probably just rely on the drive team being conditioned to deploying at a the right time. To many things could happen.
Unread 30-01-2011, 22:25
Chris is me's Avatar
AKA: Pinecone
Keep in mind the refs that will DQ you are no more able to see the milisecond differences between legal and illegal than your drivers are. For that reason I think it has to be manual.
Unread 30-01-2011, 22:47
zbanks zbanks is offline
AKA: Zach Banks
FRC #0529 (Mansfield Hornets)
zbanks is an unknown quantity at this point
Send a message via AIM to zbanks
I think it'd be a nice touch. When you're driving, it's hard to look up at the screen to see the remaining time. (I don't know how many audible bells there will be this year: just 15 sec mark, just 10 sec mark, or both)
It'd be nice to have it display on the dashboard with indicators relevant to minibot deployment.
That being said, I don't think there's any reason to automate or regulate deployment. As long as the driver knows how much time they have, you should be able to trust them to do what they want. You wouldn't want any "smart" system to get in their way.
Still, it'd be tempting to have the last 15-20 seconds completely automated.
And for those thinking of implementing a timer, make sure to start when teleop starts! The period between auto & teleop can change by a few seconds.
Unread 30-01-2011, 23:39
sjspry sjspry is offline
FRC #1984
sjspry has a spectacular aura aboutsjspry has a spectacular aura aboutsjspry has a spectacular aura about
If there's any match timers, like said above, that denote 10s, etc, you could have someone hit a button for each one and collate them (as in, you know they should be 5s apart, either take their median as the 7.5s mark, or do something similar but modify the countdown you've been doing all along).
Unread 30-01-2011, 23:44
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
It seems like everyone's forgetting something important here... Yes, it's difficult for the drivers to watch the timer and drive at the same time. But isn't that what the COACH is for? I know our COACH is going to be keeping one eye on the clock the entire time, and yelling into the drivers ear when it's time to deploy.
Unread 30-01-2011, 23:46
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
This is probably a bad idea. The best case scenario here is that you end up exactly the same as a manual deployment. In addition you will be distracting one of your two drivers to try and hit a button when they should probably be doing something else.
The worst case is that the button is not hit and your minibot doesn't deploy or is hit accidentally and deploys early.
Eagle, if you mean your coach will tell the driver when to lineup for deployment I agree. If you are going to add a second persons reaction time into your loop for the deployment itself I would not do that if I could possibly help it. Average human reaction time is around 200ms, adding the time it would take the coach to verbalize the command means that your minibot is probably a half second or more behind.
Unread 31-01-2011, 00:00
AKA: Pinecone
The drive base should be next to the goal 5 seconds before the 10 second mark. The driver's finger needs to be on that button and as soon as the number 10 is on the screen they hit it.
Unread 31-01-2011, 00:17
pfreivald's Avatar
AKA: Patrick Freivald
We're thinking about using a timer, and then putting a (very) slight delay on it to ensure that we don't have premature deployment...
...and making that code easy to overwrite to driver-triggerable if, during our practice games on Thursday, it draws penalties for some reason.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 31-01-2011, 00:23
demosthenes2k8's Avatar
demosthenes2k8 demosthenes2k8 is offline
Graduated but not gone
AKA: Matt Soucy
FRC #0166 (Chop Shop 166)
demosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to behold
Send a message via AIM to demosthenes2k8 Send a message via Yahoo to demosthenes2k8
My team has the Proxy class of our framework (which is a task that updates 50 times a second) handle a timer counting down remaining match time, and are setting the code up so that the robot will essentially ignore that button until 10 seconds remain. This means that they can hold it down, and it will "trip" as soon as the robot sees 10 seconds remaining, or just deploy at will after that time.
GSR Dean's List Finalist 2011
Unread 31-01-2011, 04:34
Nadav Zingerman Nadav Zingerman is offline
FRC #2230
Nadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to behold
Why is everyone talking about looking at the clock when the tower bases change color when it is time to deploy? Seems like a much more convenient place to look at while also driving your robot.
I think that using a timer to deploy is a great idea, one that we have considered and implemented. Every millisecond can count in the minibot race, and a timer could easily shave off a few hundred, perhaps an entire 0.5 seconds. You have practice matches to see if you get penalties. If you do, change it to manual. Prepare both robot codes and have drivers practice both.
