Go to Post Pulling off an off season during a hurricane isn't easy. - Arefin Bari [more]
  #31   Spotlight this post!
Unread 31-01-2011, 00:16
fox46's Avatar
fox46 fox46 is offline
FRC #2013 (Cybergnomes)
fox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond repute
Re: Stalling the BaneBot 775 motors
Whatever the capacitor is in the middle of the ring of transistors is.
For the purpose of this discussion I think we are getting too far into the theory behind the component.
This is pretty basic AC circuit theory, and it has a profound effect (40 watts versus 200 watts) on the answer you get, so it's worth understanding
I agree but seems like this is much more than a basic AC circuit when we are apparently not dealing with changes in frequency but rather changes in duty cycle. The original purpose of the OP's question was to determe if it was acceptable to stall the RS775 at 20% power. My OPINION is that it is not acceptable, but by all means, go for it- you are only burning up 40W right? Last I checked, a 20% position of a joystick did not result in a 4% robot speed.
The duty cycle varies linearly with input command
Okay but we are not concerned with the duty cycle but rather the output power which according to you is not linear to the input command. I disagree with this.
Not sure what you mean by "exponentially" here. The effective voltage changes linearly with input command, and the effective current also changes linearly. The effective power thus changes as a square function.
Sorry, this is what I meant- Power is not linear to input using your method, as I stated earlier. "Exponentially" was the wrong term to describe this.
In any case, I still think the output is closer to 200W than 40W. I'll bet you the OP's RS775 . Let me know what your simulation shows. Until we come up with some actual Jaguar output wattages relative to control inputs lets just agree to disagree. When we get our software up and running and if I get around to it. I'll measure the percieved voltage and current going to our RS775s and plot it relative to input value in the program. Then we can see if the output power is linear or nonlinear to input command.
Mentor, Team 2013 Cybergnomes 2010 - 2014, 2016
Mentor, Team 3756 RamFerno 2011 - 2013
Mentor, Team 854 Iron Bears 2005-2007
Founding member, Team 854 Iron Bears 2000-2005
Mech.Eng.+Mgt University of Ontario 2009
B.Ed OCT Trent University 2015
Professional Education and Product Knowledge Consultant - Toyota Canada Inc.
  #32   Spotlight this post!
Unread 31-01-2011, 00:52
Here's the FET bridge portion of the Black Jag. As you can see, there is no filter capacitor on the Jag's output.
With the rotor stalled (which is what we're discussing) it's just a switched LR circuit.
Correct.
I do not know how long the RS775 can tolerate 40W without overheating. I suggested to Leav that he run some low-power tests to determine at what point the motor starts to become uncomfortably warm to the touch.
I don't know where you got that from. I hope you do not think I am claiming that.
I already ran the simulation with 20 uH and it shows 40 watts. I do not know what the actual inductance is but I suspect it is higher than that.
