Go to Post It's a skid-steer vehicle, so it depends on the phase of the moon and yesterday's lottery numbers. - Ether [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 29-01-2011, 13:09
jhaw jhaw is offline
FRC #0910
jhaw is an unknown quantity at this point
motor pulsing in can mode
We have downloaded the code from Kamocat. When we control the cim motors through the joy sticks then motors pulse. Any thoughts.
Unread 29-01-2011, 21:31
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
Re: motor pulsing in can mode
Sure.
I'm assuming your Jaguars have the correct device IDs. (11 and 12 for Left and Right drive)
The code I provide is in Speed mode, meaning it requires encoders to be connected.
I can provide pictures if that would help.
Assuming those are set up correctly, the issue is probably related to PID tuning. I've recently changed the PID tuning to be a lot more controllable at low speeds. (P is now 0.3 and I is 0.01. D is still zero)
If none of those are the issue, I'll need to know more information.
Where did you download the code from? If it's GitHub, I'll also need to know the approximate date, as that is a working repository.
Thanks!
-- Marshal Horn
Unread 31-01-2011, 00:35
duane's Avatar
duane duane is offline
FRC #0701 (RoboVikes)
duane is an unknown quantity at this point
Send a message via AIM to duane
My mistake. I stand corrected. I think I'll delete the entire post so as not to confuse any later readers.
Duane Murphy
Mentor - Software
Vanden Vikings FIRST Team 701
http://www.vandenrobotics.com
Unread 01-02-2011, 20:00
ASHpwnall ASHpwnall is offline
FRC #0910
ASHpwnall is an unknown quantity at this point
I Speak for our Team 910? We "Fixed" the problem... i don't know how but i was told to post it because jhaw cannot log in to ChiefDelphi... so no need to worry!
