Go to Post I'm impressed and incredibly amused that you found so many of Dave's evildoings, though granted, they aren't that hard to search out. - DCA Fan [more]
  #31   Spotlight this post!
Unread 28-01-2011, 23:30
Christian Z's Avatar
Christian Z Christian Z is offline
FRC #2557 (Sota Bots)
Christian Z is an unknown quantity at this point
Re: Minibot Falling Solutions
well we were thinking of not using the brick but we didnt want the motors to be at full power so they don,t burn out.
  #32   Spotlight this post!
Unread 28-01-2011, 23:35
sam_who sam_who is offline
FRC #2190
sam_who is an unknown quantity at this point
Doug G - Is that Bertrand Russell the amateur rocketeer?
  #33   Spotlight this post!
Unread 29-01-2011, 00:38
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
So I've had a brainstorm that I'm both anxious and terrified to try out. Those Tetrix motors are expensive after all. All this requires is a standard 4-way light switch and a little faith. For those not in the know, a 4-way light switch takes two inputs and swaps them back and forth. Switch up and A->1, B->2, switch down and A->2, B->1. So, if you have an appropriate drive mechanism, one creatively wired 4-way switch should be all you need to reverse your robot and bring it down at a moderately controlled speed.... Now, stay with me here, cause this is a little crazy.
To get a 4-way switch to reverse your motors, you'd wire battery + and - to the input side, and motor + and - to the output side. Switch up, motor goes one way (up), switch down, motor goes the other (down). Wire both motors to the output, and they both get reversed. Rig this to reverse the motors at the top, and after your minibot's meteoric rise to the target will come a much much more meteoric plummet to the earth.
So how about this.... Wire one motor to the 4-way output normally. It gets reversed at the top. For the second motor, wire ONE lead to the correct (upwards) 4-way output. Wire the other motor lead straight to the correct battery lead. When the switch is flipped, this second motor is gets shorted to itself across the switch, causing it to regen brake, thus slowing down the minibot a rather good bit.... I think. But this circuit looks like it might have some... interesting... dynamics, as the second motor is in the return current path of the first motor, which I'm having trouble thinking out properly at the moment. So don't try this at home yet until I work out whether I'm being a little too clever here.
To the electricians in the audience, yes, you could hook the second motor up to its own 3-way switch to isolate it from the circuit, but that's a whole extra switch's worth of complication and weight. We're on a strict diet here, man!
  #34   Spotlight this post!
Unread 29-01-2011, 02:16
kromero18's Avatar
kromero18 kromero18 is offline
FRC #0399
kromero18 is an unknown quantity at this point
Originally Posted by nitneylion452 View Post
What if we buy a really long overcoat and have 3 people stand on each other's shoulders, then they wear the coat. It would appear that it is one person, but it's not.
love this idea! it should work
Eat.Sleep.Robotics
  #35   Spotlight this post!
Unread 29-01-2011, 07:59
2bkrul's Avatar
2bkrul 2bkrul is offline
Whats tht burnin smell..oh the Jag!
AKA: Brandon Krul
FRC #0964 (Bedford Robotics)
2bkrul is an unknown quantity at this point
Originally Posted by jhellr13 View Post
Yeah, that rule is so hard to interpret. Hopefully it will be interpreted into greater depth in a future team update.
Why don't you have your mentor or another team member go on the Q&A and ask. Yes CD is helpful by getting others opinions on rules, but the GDC knows ALL.
Just sayin'
"Building robots is a lot better with doughnuts around"
-Team 964 2010 Team Motto
Team 964 on TBA!
The Home of Bedford Robotics!
  #36   Spotlight this post!
Unread 29-01-2011, 08:35
mott's Avatar
mott mott is offline
AKA: Mike Ott
FRC #1619 (Up-A-Creek Robotics)
mott is on a distinguished road
As with other portions of Team Update #6, this Minibot retrieval rule leaves some room for interpretation.
What does everyone think of this: If you actually carried a "retrieval stick" or gaff-like device on your hostbot throughout the match (and subjected it to Robot Inspection with the rest of your machine), would this device actually qualify as "special equipment"??? Or, we could be creative and make a long section of our Bumpers have a hook (also known as attachment hardware) that we could hook our Minibot with to pull it down...
If your retrieval stick is part of your Hostbot/Robot (even though without function during the match) could it be considered "special"?
Comments welcome but a GDC Q&A might be in order.
  #37   Spotlight this post!
Unread 29-01-2011, 10:34
Karibou Karibou is offline
Steel is love. Steel is life.
AKA: Kara Bakowski
FRC #0341 (Miss Daisy)
Karibou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond repute
Send a message via AIM to Karibou
Originally Posted by Kevin Sevcik View Post
Have you empirically tested this yet? I'm roughly estimating you'd need someone atleast 6'6" to make that reach. And that's assuming your minibot hangs down 12" from the target. You'd need someone about 7'2" to reach up to 122". This is assuming my rough body proportions math scales properly, and no jumping, of course.
If you have a girl (...or a guy, I suppose) that's 6', it's not incredibly hard to find 6" high-heels. Just throwing that out there.
Now that I think about it, would stilts be considered "special equipment" if they were worn by a drive team member during a match? They wouldn't have to be more than a few feet high. I wonder if they would be legal, as unlikely as it would be.
Kara Bakowski
Michigan Technological University///Materials Science and Engineering '15///Go Huskies! #tenacity
kabakowski(at)gmail(dot)com
FRC 341 (2016-present): Mechanical/build mentor
Volunteer (2010-present): MAR Seneca '17, FTC Hat Tricks Qualifier '16, Brunswick Eruption '16, MAR Montgomery '16, MAR Westtown '16 Portcullis Victim, MAR Springside-Chestnut Hill '16, Ramp Riot '15 '16, FiM Escanaba District '14 '15, MidKnight Mayhem '13 '15 '16, FiM Detroit District '13, IRI '10 '12, FiM Waterford District '11 '12, MARC '12, CMP Galileo '11
FRC 1189 (2008-2011): Team Captain, Pit Crew, Website group leader, Team Education group leader, Proud Alum. We've got spirit, yes we do...
WMWBS '10 '11
  #38   Spotlight this post!
Unread 29-01-2011, 11:56
Your arm length is approximately the same as your height. Thus, if you're 6 inches shorter, your reach is approximately 12 inches less, so you'd need 12" platforms.
  #39   Spotlight this post!
Unread 29-01-2011, 12:40
I was actually working this off general body proportions and some fudging for stretching up and standing on your toes. My mostly guesswork formula comes out as Reach = Height * 11 / 8. I'm 70" and I can reach my 96" ceiling standing on my toes, so all of my data points agree well with my formula....
  #40   Spotlight this post!
Unread 31-01-2011, 01:33
JB987 JB987 is offline
AKA: Joe Barry
FRC #0987 (HIGH ROLLERS)
JB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond repute
There have been several demonstrations of great performing minibots slowly returning to the base of the tower after reaching the target. Kudos to them. Given Update #6 restriction on using assistive devices to retrieve a minibot is there a team who has figured out how to achieve a slow return willing to share their solution as a way to help possibly hundreds of teams avoid the potential damages likely to happen from free fall situations? For example, many teams designs won't be able to take advantage of a shorting of motor leads to act as a break of sorts because they don't backdrive. I don't see how sharing would give away any potential competitive advantage since it has no effect on the race to the target... and see great advantage to helping a fast minibot that could be potentially be your alliance partner stay intact enough to benefit your team as well...
  #41   Spotlight this post!
Unread 31-01-2011, 01:49
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Originally Posted by JB987 View Post
There have been several demonstrations of great performing minibots slowly returning to the base of the tower after reaching the target. Kudos to them. Given Update #6 restriction on using assistive devices to retrieve a minibot is there a team who has figured out how to achieve a slow return willing to share their solution as a way to help possibly hundreds of teams avoid the potential damages likely to happen from free fall situations? I don't see how sharing would give away any potential competitive advantage since it has no effect on the race to the target... and see great advantage to helping a fast minibot that could be your alliance partner stay intact enough to benefit your team as well...
When a DC motor backdrives, it acts like a generator and generates electricity. To slow the backdrive, add a load onto the system by isolating the motor from the battery and shorting the two motor leads together after the Minibot reaches the top of the pole. The Minibot will then roll down the pole slowly.
Art Dutra IV
世上无难事,只怕有心人.
  #42   Spotlight this post!
Unread 31-01-2011, 01:55
AKA: Joe Barry
Thanks for sharing Arthur...as you were adding to the thread I was editing to mention that many teams won't be in a backdriving condition that could take advantage of shorting the motor leads...so what other alternatives are out there?
  #43   Spotlight this post!
Unread 31-01-2011, 02:04
artdutra04's Avatar
You can use a DPDT switch to reverse the motor direction when it hits the trigger. To stop the robot at the bottom, a limit switch could be added.
Art Dutra IV
世上无难事,只怕有心人.
  #44   Spotlight this post!
Unread 31-01-2011, 02:14
AKA: Joe Barry
We have considered using a DPDT (4 way?) switch but were concerned about the downward velocity...the question is, could a limit switch (perhaps on a flexible extension) on the bottom end fit within the size limit and be far enough extended to provide a timely stop of the robot likely traveling faster than it did upward? An idea to be tested for sure. Thanks again, Arthur, for your efforts to help your fellow FRC mates!
  #45   Spotlight this post!
Unread 31-01-2011, 02:19
Ethan Spitz Ethan Spitz is offline
President
FRC #3637 (The Daleks)
Ethan Spitz is an unknown quantity at this point
Or for teams not using a NXT, you could use your second light switch to just completely cut the power. Of course in conjunction with the DPDT switch (or 4-way switch I believe it is also called)
www.team3637.com FIRST team 3637's Website: The Daleks
