Go to Post I won't tar and feather you, I'll disagree though. - Andrew Schreiber [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 30-01-2011, 10:56
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
Jaguar Speed Control Only Reaches 50% of Setpoint
We've "successfully" gotten our CAN Jaguars working under speed control.
We've tuned the PID constants to get a system that seems to react nicely, and is stable.
The only problem, our system only reaches 50% of the setpoint speed.
Anyone else notice this?
When we setX() at 60 RPM, getSpeed() shows only 30 RPM is attained.
I'm pretty sure I know why this is happening, but I'd like to confirm others are seeing this too.
In life, what you give, you keep. What you fail to give, you lose forever...
Unread 30-01-2011, 13:51
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
Re: Jaguar Speed Control Only Reaches 50% of Setpoint
There's two possible causes:
Either you're going as fast as the motor can, or you need to include some Integral into your tuning.
If you're providing full power, then the Jaguar LED will be solid green (or solid Red if you're in reverse)
-- Marshal Horn
Unread 30-01-2011, 15:16
AKA: Mr. Lim
Can you confirm that a P-Only control loop will only get you half-way to the setpoint?
I have some concerns that the speed control mode on the Jags is missing some important functionality.
If the P term doesn't accumulate in velocity control, it will go to 0 as it gets closer to the setpoint. This usually results in a P-only loop appearing stable, but only hitting about 50% of the setpoint.
A workaround is to have an I term that will get you all the way to the setpoint. However, I've heard elsewhere that the I term goes to zero as soon as the setpoint is attained, so as to prevent overshoot/wind-up. I can't confirm this 100%, but based on some initial testing I'm led to believe this is the case, as an I-only loop seems to hit the setpoint, then cuts out, only to accelerate up to the setpoint and cut out again.
Right now, we're using a P-only loop, setting the setpoint twice as high as we really want it. It's a sloppy workaround, but the best we've come across so far.
Unread 30-01-2011, 15:35
RyanCahoon's Avatar
FRC #0766 (M-A Bears)
I've not used CAN on the Jags before, much less the PID control, but is there a configuration that has to be set for number of clicks/rev on the encoders?
FRC 766, 2015-, Mentor
Unread 30-01-2011, 16:33
kamocat's Avatar
Test Engineer
AKA: Marshal Horn
Yes, without an I coefficient, you can't expect to ever reach the setpoint; you get partway there, and then don't go any further.
I haven't tried an I-only loop.
If you're intent on using P only, what happens when you double your P coefficient? Is that the point where it starts to oscillate?
-- Marshal Horn
Unread 30-01-2011, 20:54
wmarshall wmarshall is offline
FRC #0011
wmarshall will become famous soon enough
I'm in the process of tuning the Speed PID loop on my team's Jaguars, and I'm having a similar issue. Using BDC-COMM to set the PID values, I can increase P until I get to just under my setpoint, but when the loop actually hits the setpoint, the Jags start freaking out and flipping the motor direction very quickly, before faulting. This has made it nigh impossible to get anywhere, as the method I'm using to tune the loop (Wikipedia) needs the loop to hit the setpoint.
At a stable P(no sad gear grinding) the output is much lower than the setpoint, and as P is increased to hit the setpoint, the loop gets more prone to the gear grinding. I've yet to even begin to play with the I value, as I fear it may lead to more instability.
Unread 30-01-2011, 21:03
By definition, it is impossible to stably hit your set point with a P only control loop. You must have an I term.
A PID loop is calculated with respect to the error, or difference between what you want and what you have. As you approach the setpoint, the error approaches 0. Therefore, the output of the P term approaches 0. Therefore, with a P only loop you will always undershoot your target. You can jack the P gain up to reduce the undershoot, but it will never be zero. If you jack it up too high, noise will dominate and the whole thing will go unstable.
Keep the P where you have it (hitting half your goal) and add a bit of I.
Unread 30-01-2011, 21:41
AKA: Mr. Lim
My workaround has been to tune the P-only loop to react as best as can be to exactly half the setpoint.
I can confirm that when you crank the P to actually try and hit the setpoint, bad things happen. It'll get you there, only to slam in reverse, and oscillate around the setpoint...
I'll get a chance to add I term to see if it will actually get me to the setpoint in a stable manner.
I'm curious if anyone know exactly how the Jaguars deal with Integral wind-up. Whether it reduces the I-term to 0 once the setpoint is hit, or does it cap the accumulated I value to some kind of ceiling?
Either way, I think we'll get a chance to find out tomorrow!
Unread 30-01-2011, 22:04
techhelpbb's Avatar
FRC #0011 (MORT - Team 11)
I'm a mentor for wmarshall's team and I have a request into TI for actual documentation on the transfer function, LaPlace or block diagram for the FIRST firmware Jaguar PID functions.
It's more curious to me that the P loop doesn't always reach the point of instability eventually for any given value of P.
In theory, a small P should move more slowly toward the set point but still get there eventually.
This does not seem to be the case and that leads me to believe this is not a parallel PID algorithm.
If I get anywhere I'll let you all know.
Not only do we not know how they handle integral wind up (if they handle it at all), we don't know if they have a deadzone or a D filter.
Also I'm not a fan of tuning using the Ziegler Nichols method the way I suspect we're going to get told to use it.
I'd not like to end up with marginal tuning.
Unread 30-01-2011, 22:21
The jaguar source code is available for download. http://www.luminarymicro.com/products/rdk-bdc24.html
Unread 30-01-2011, 22:44
I've never heard of such a thing. It would seem to defeat the whole purpose of the integral controller.
Unread 31-01-2011, 03:58
techhelpbb's Avatar
It is my understanding, though I could be wrong, that the FIRST firmware differs from the commercial firmware.
I know that the FIRST firmware operates in trusted mode where as I'm fairly sure the commercial firmware does not.
Also I've noted that TI has mentioned to other people using the 'Jaguar' for non-FRC purpose they shouldn't use the FIRST firmware as the FIRST firmware has 'safety features' for FIRST (basically).
This leads me to wonder if I'd be wasting my time reverse engineering the source code. Though frankly, in a more commercial sense, I can't imagine being told to reverse engineer the source code for a commercial controller just to get a block diagram of the transfer function or the proper tuning procedure.
Is it just me or does this link not work:
"Stellaris® RDK-BDC24 Brushed DC Motor Control Module User's Manual"
Unread 31-01-2011, 04:16
techhelpbb's Avatar
I suspect what they are hoping to communicate would be to eliminate noise induced run away. If you get noise that interferes with your return function then over a duration then...for example...you might end up 'winding up' the I in such a way that even though you've limited it...it's still way too high and because of it getting to high over and over from disturbance and noise it may never come down and the result might be perceived as erratic movement.
If you can 'reset' the I (not necessarily make the I constant 0), and do it when the I is perceived to have 'wound up' too often, then you can effectively prevent yourself from having to reset the entire PID loop to eliminate what appears to be erratic function.
As an example...
http://community.mybb.com/thread-78886.html
Unread 31-01-2011, 10:49
AKA: Mr. Lim
The crux of this issue is that the PID implementation seems to be more suited to position control, rather than speed control.
Killing the I term when the setpoint has been reached is commonly employed in position control - particularly in systems where there is a lot of resistance as you slowly reach your desired position. When you are finally reach the setpoint, your P is already 0, and it's in your best interests to 0 the I term to prevent overshoot. The I has already done its job to get to the setpoint, to overcome any resistance encountered on the way there.
Regardless, I can't 100% confirm what the I term behaviour is until later this afternoon, but I'm hoping the I-term is capped, rather than 0'ed.
Unread 31-01-2011, 11:15
techhelpbb's Avatar
(I posted this last night, but it claimed it needed approval so I'll try again).
limited it...it's still way too high and because of it getting too high
As an example...
When the goal is to achieve a set point of a fixed speed, then I can see how this helps when the prime concern is the change in set point.
As noted above, when the prime concern is achieving the set point position it makes sense when the loading is prone to bind at the last second. Though, the kind of binding matters. If for example the mechanism is prone to binding and then runaway (the motors are overloaded and then break free) then you're probably too close to the limits of the ideal, serial or parallel algorithms for the stable D to be achieved anyway in which case now you have a special case.
