Go to Post Between Andy B. and Andy G. being Andy A. has some unspoken expectations put on it. - Andy A. [more]
Unread 31-01-2011, 08:40
C_Helm C_Helm is offline
FRC #1742
C_Helm has a spectacular aura aboutC_Helm has a spectacular aura about
Tetrix motor tab broken
In the process of trying to un-solder the connecting wire from the motor, one of the motor tabs broke off. Is there any possible way to fix this?
Unread 31-01-2011, 09:35
Ethan Spitz Ethan Spitz is offline
President
FRC #3637 (The Daleks)
Ethan Spitz is an unknown quantity at this point
Re: Tetrix motor tab broken
Not sure if its competition legal, but we took a soldering iron and melted the plastic around were the tab was and soldered on wires to the metal tab that was exposed.
www.team3637.com FIRST team 3637's Website: The Daleks
Unread 31-01-2011, 17:35
LMD3130 LMD3130 is offline
Team Captain
AKA: Liam Driscoll
FRC #3130 (ERRORs)
LMD3130 is an unknown quantity at this point
This has just happen to us
Unread 01-02-2011, 10:07
This is pretty risky as there are electrical parts on the inside of the tab you are soldering.
Unread 01-02-2011, 11:13
President
Well considering you already can't use the motor because the tabs are broken off there is no reason not to try. Additionally you only have to melt through a tiny bit of plastic so you can get a bit of solder on there. Its not like you are holding the soldering iron there for 30 seconds, its more of a just a touch and the plastic around it melts away enough to get solder to stick.
Ethan
