Go to Post You are certainly welcome to demonstrate your geekiness on a regular basis! :) - Cynette [more]
Unread 29-01-2011, 15:30
tluks tluks is offline
None #1126 (sparx)
tluks is an unknown quantity at this point
Joystick getAxis in wpilibj
WPIlibj currently has:
public double getAxis(final AxisType axis) {
switch (axis.value) {
case AxisType.kX_val:
return getX();
case AxisType.kY_val:
return getY();
case AxisType.kZ_val:
return getZ();
case AxisType.kTwist_val:
return getTwist();
case AxisType.kThrottle_val:
return getThrottle();
default:
return 0.0;
I think there should also be:
case AxisType.kNumAxis_val
before the default. Does anyone know where wpilibj issues can be reported?
Unread 31-01-2011, 16:24
ProgrammerMatt ProgrammerMatt is offline
Programmer-Electrical-Mechanical
FRC #0228 (Gus)
ProgrammerMatt is just really niceProgrammerMatt is just really niceProgrammerMatt is just really niceProgrammerMatt is just really nice
Lightbulb Re: Joystick getAxis in wpilibj
If you mean like
joystick.getRawAxis(#)   //#= AxisNumber
Unread 31-01-2011, 18:37
wpilib bugs can be reported in the wpilib tracker: http://firstforge.wpi.edu/sf/tracker...ilib_java_bugs
Unread 31-01-2011, 19:13
Ryan O's Avatar
Ryan O Ryan O is offline
FRC Eclipse Plug-in Developer
no team (FRC Eclipse)
Ryan O is an unknown quantity at this point
Send a message via AIM to Ryan O
In case that link ever changes, I will also mention it is included in the Eclipse Plug-in help, if that is the IDE and FRC Plug-in set you are using. It can be found by following the "report bugs" link on the troubleshooting page of the help contents for both the core and program builder plug-ins.
CRUD Name: Windows
Alumni to Team: 350
