Go to Post know what else would be great? with each new rep point you get 10 airline miles on your Visa or MasterCard - KenWittlief [more]
Unread 31-01-2011, 16:58
Back @ it again with the white vans
AKA: Brandon Liatys
FRC #2180 (Zero Gravity)
What motors to use?
We're trying to figure out what motors to use to control our arm with the tube grabber on the end, and ran into problems. We tried using a window motor, and it could not lift the grabber on the end of a pole. We then tried two window motors and it still couldn't do it. They were both direct drive, no gearing.
So then we turned our attention to the fisher price gearbox, but couldn't get the motors in them. We'd stick the motors in and screw them in, but when we ran power to it it couldn't turn as if it was jammed. After playing with it for awhile we found that it only works in some weird position that doesn't allow you to screw the motor in. Has anyone else had this problem? we tried all the motors we had with the gear on the end and it happened with all of them.
The grabber is pretty heavy, But we are putting it on a weight loss program
EDIT: Without CIMs, if possible..
Unread 31-01-2011, 17:07
Joe G.'s Avatar
Joe G. Joe G. is online now
AKA: Josepher
no team (Formerly 1687, 5400)
Re: What motors to use?
Both window motors and the FP can work for this application, but both also benefit from gearing. A one or 2 stage chain reduction is fairly simple to build, and will reduce speed to a manageable level.
Vikesrock's Avatar
Vikesrock Vikesrock is online now
Team 2175 Founder
AKA: Kevin O'Connor
You may have a Fischer Price gearbox that does not match your motor pinion. The pinion the gearbox is designed for is molded into the outside of the gearbox (two places I think, don't remember where), it should be something like "19T" or "17T". Make sure this number matches the number of teeth on the pinion for your 2011 FP motor.
Unread 31-01-2011, 17:12
AKA: Brandon Liatys
We used the gearbox we got this year (the orange one) with the motor with the orange collar, which already had a gear on the end of it. I didn't know that and didn't count but I thought orange+orange=good lol
Unread 31-01-2011, 17:22
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
You'd think so. I haven't actually seen a KOP from this year, my observation was based on our team getting FPs and gearboxes in the past that didn't match.
