Go to Post FRC did a lot for me in high school. I couldn't pass up the opportunity to help it do the same for others. - Oblarg [more]
Unread 31-01-2011, 18:20
101is5 101is5 is offline
FRC #3521
101is5 is an unknown quantity at this point
Missing motor, servo, joystick controls missing
We were planning on programming on a seperate computer, but the version of labview is missing the WPI Robotics Library functions. Is this on an update, and if it is how do I install the update?
You can be a Noble Nut too!
Shadow Hills HS Team 3521, Noble Nuts
Unread 31-01-2011, 20:43
Re: Missing motor, servo, joystick controls missing
You need to read the directions on the Kit of Parts web page. The specific document you want is Getting Started with the 2011 Control System. Don't overlook the part about installing the updates on pages 3 and 4.
Unread 02-02-2011, 18:16
FRC #3521
Thank you so much for the help, this will be very helpful in the future.
