Go to Post That's awesome. I sort of like the smaller venues. You get to know teams on a lot more personal level. - thisOrrthat [more]
Unread 31-01-2011, 19:49
ElliotCourant's Avatar
ElliotCourant ElliotCourant is offline
Elliot Courant
AKA: Elliot Courant
FRC #3038 (ICE Robotics)
ElliotCourant is an unknown quantity at this point
Accelerometer
So I'm trying to implement the accelerometer, and i get several errors.
RobotDemo(void):
		myRobot(1, 2, 3, 4),	// these must be initialized in the same order
		leftstick(1),		// as they are declared above.
		rightstick(2),    	// as they are declared above.
		gyro(1,1),
		acc(I2C)
and it gives me this
C:/WindRiver/workspace/Final/MyRobot.cpp:34: error: expected primary-expression before ')' token
How do I implement the accelerometer?
"Error, Cannot Find Back-End!" -WindRiver C++ Error
"If you aren't getting any errors while you are programming, then you are doing something wrong." -Elliot Courant
