Go to Post To have respect for the process you are in right now, respect the knowledge around you by using it to your full advantage. - Scott Ritchie [more]
Unread 28-01-2011, 14:39
mastergamer1231's Avatar
mastergamer1231 mastergamer1231 is offline
FRC #0869
mastergamer1231 is an unknown quantity at this point
Exclamation How do I upload code to the Robot with Java?
Hi everyone,
Our team has just realised something, we don't know how to upload code with Java! This is our first year with Java and we have Netbeans 6.9.1.
Thanks in advance!
Unread 28-01-2011, 15:16
wdell wdell is offline
AKA: William Dell
FRC #3999 (Shadetree Mechanics)
wdell has a spectacular aura aboutwdell has a spectacular aura about
Re: How do I upload code to the Robot with Java?
First question: have you reimaged the cRio to accept Java?
Assuming you have sorted that out it's pretty simple. You connect your computer to the cRio with a crossover cable, and then in Netbeans hit "Run". The actual routines to copy it over to the bot are handled by Netbeans.
Unread 28-01-2011, 21:57
el-zoroo el-zoroo is offline
Chief Operating Officer
AKA: Zuhair
FRC #2374 (Crusaderbots)
el-zoroo is an unknown quantity at this point
Hi,
In the ideal world, the steps to download Java are:
1) Reimage the cRIO with the Java specific image.
2) Update Netbeans with the FRC plugins.
3) In Netbeans, in Tools>Options>Misc>FRC Configuration, update the Team Number.
4) Hit Run and cross your fingers
I assume all your networking is up and running properly (i.e., you should be able to ping the cRIO).
You can find more detailed information at How to Build and Load Programming in LabVIEW, C++, and Java
Hope that helps!
Unread 31-01-2011, 18:02
buildmaster5000 buildmaster5000 is offline
Trying to program the swerve drive
AKA: Alex
FRC #2421 (Rolling Thunder Robotics)
buildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud of
It should be noted that while many of the instructional documents that FIRST provides say that the user should use a crossover cable, it is only necessary between the camera and the cRIO. The bridge, classmate, and most other modern devices (computers, routers, etc.) have auto switching ports that will make a non crossover cable into a crossover if needed. This makes it a lot easier to acquire cables since crossovers are hard to find.
-Alex
2010 Washington DC Regional: Engineering Excellence Award
Unread 31-01-2011, 20:04
Omgsar's Avatar
Omgsar Omgsar is offline
AKA: Evan Gray
FRC #2745 (S.A.R.)
Omgsar is an unknown quantity at this point
Our team is having the same issue,
[cRIO] edu.wpi.first.wpilibj.util.AllocationException: PWM channel 3 on module 4 is already allocated
[cRIO]     at edu.wpi.first.wpilibj.PWM.initPWM(PWM.java:112)
[cRIO]     at edu.wpi.first.wpilibj.PWM.<init>(PWM.java:141)
[cRIO]     at edu.wpi.first.wpilibj.SafePWM.<init>(SafePWM.java:33)
[cRIO]     at edu.wpi.first.wpilibj.Jaguar.<init>(Jaguar.java:41)
[cRIO]     at edu.wpi.first.wpilibj.RobotDrive.<init>(RobotDrive.java:110)
[cRIO]     at edu.wpi.first.wpilibj.templates.Team2745Robot.<init>(Team2745Robot.java:27)
[cRIO]     in virtual method #11 of com.sun.squawk.Klass(bci=53)
[cRIO]     at com.sun.squawk.imp.MIDletMainWrapper.main(99)
[cRIO]     in virtual method #95 of com.sun.squawk.Klass(bci=25)
[cRIO]     at com.sun.squawk.Isolate.run(1506)
[cRIO]     at java.lang.Thread.run(231)
[cRIO]     in virtual method #47 of com.sun.squawk.VMThread(bci=42)
[cRIO]     in static method #3 of com.sun.squawk.VM(bci=6)
Unread 31-01-2011, 20:28
Robototes2412's Avatar
Robototes2412 Robototes2412 is offline
1 * 4 != 14
FRC #2412 (Robototes)
Robototes2412 is on a distinguished road
code plz?
Unread 31-01-2011, 20:31
Patrick Chiang Patrick Chiang is offline
Programming
FRC #3070 (Team Pronto)
Patrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to all
You allocated the same PWM twice. Look in your code for the following line:
new PWM(3);
If you find two of them, delete one of them. If you find one, something else is wrong and I can't help unless I get more code.
Unread 31-01-2011, 21:10
Omgsar's Avatar
AKA: Evan Gray
FRC #2745 (S.A.R.)
Here are all of our declarations:
 public Joystick leftStick = new Joystick(1);
    public Joystick rightStick = new Joystick(2);
  public Jaguar jagFrontLeft = new Jaguar(1);
  public Jaguar jagFrontRight = new Jaguar(2);
   public Jaguar jagBackLeft = new Jaguar(3);
    public Jaguar jagBackRight = new Jaguar(4);
    public RobotDrive driveRobot = new RobotDrive(1, 3, 2, 4);
    public Gyro roboGyro = new Gyro(7);
    double leftX =0;
    double leftY =0;
    double rotationRate =0;
    double gyroAngle =0;
    int i = 0;
Unread 31-01-2011, 21:37
AKA: William Dell
Thank you! I've been using a crossover cable that for some reason needs one particular end plugged into the cRio, and it's driving me nuts. I do it all wireless now so I don't have to keep track of that $@#$@#$@#$@# cable!
Unread 31-01-2011, 21:40
AKA: William Dell
If I'm reading that right look at line 27 in Team2745.java. Or post the first 27 lines of that class so we can take a look at it.
Unread 31-01-2011, 21:49
AKA: William Dell
kk, in your declarations most of that doesn't need to be public. Try:
double leftX =0;
double leftY =0;
int i = 0;
Here's the first chunk of mine:
package edu.wpi.first.wpilibj.templates;
 * @author   William Dell
 * @author   Team 647
 * @version  v7, January 29, 2011
 * @version  FRC Java version 2011.4
import edu.wpi.first.wpilibj.SimpleRobot;
import edu.wpi.first.wpilibj.Timer;
import edu.wpi.first.wpilibj.Gyro;
import edu.wpi.first.wpilibj.Victor;
// import edu.wpi.first.wpilibj.Jaguar;  // for change to production bot
import edu.wpi.first.wpilibj.RobotDrive;
public class Main extends SimpleRobot {
    DStation station; // consolidated, simplified dash and driver station
    Joystick controllerOne = new Joystick(1);
    Timer timer = new Timer(); // one timer to rule them all....
    Gyro spinGyro = new Gyro(1);
    Kamera cam;  // consolidated web cam controller
    //------------Drive System-----------------//
    Victor leftFrontVictor = new Victor(1);
    Victor rightFrontVictor = new Victor(2);
    RobotDrive drive = new RobotDrive(leftFrontVictor, rightFrontVictor);
    /*  4 motor drive for production bot commented out here
    Jaguar leftFrontJaguar = new Jaguar(1);
    Jaguar leftRearJaguar = new Jaguar(2);
    Jaguar rightFrontJaguar = new Jaguar(3);
    Jaguar rightRearJaguar = new Jaguar(4);
    RobotDrive drive = new RobotDrive(leftFrontJaguar, leftRearJaguar,
    rightFrontJaguar, rightRearJaguar);
    AutoDrive autodrive; // simple autonomous routines
     * This method is called once when the robot boots up.
    public void robotInit() {
AND I just found your problem. You're declaring your robot drive wrong. You have
when you should have
RobotDrive driveRobot = new RobotDrive(jagFrontLeft,jagBackLeft,jagFrontRight,jagBackRight);
What was happening is it would hit the Jaguar declaration and assign the PWM port to the jag. Then you're RobotDrive declaration would try to assign the PWM ports directly instead of going through the jaguars.
Unread 31-01-2011, 23:27
Programming
/* Here, the cRIO allocates slot 1-4 of the PWM.
Which means if you try to allocate them again in
another part of the code, you'll get errors. */
/* See? Here, you're allocating the EXACT SAME
PWM slots AGAIN. Which creates problems and are
 most likely the cause of your problem. */
Comments in navy blue. Here's the solution:
/* Code removed because it creates problems */
// Jaguar jagFrontLeft = new Jaguar(1);
// Jaguar jagFrontRight = new Jaguar(2);
// Jaguar jagBackLeft = new Jaguar(3);
// Jaguar jagBackRight = new Jaguar(4);
double leftX =0;
double leftY =0;
int i = 0;
Edit: Darn. Someone beat me to it.
Unread 31-01-2011, 23:50
Omgsar's Avatar
AKA: Evan Gray
FRC #2745 (S.A.R.)
Ahh, noob mistake. Haven't touched java in forevers. Thanks All.
