Go to Post In the end, if our products are crap, then people will not buy them. This is the risk of doing business, and the foundation of capitalism. - Andy Baker [more]
Unread 31-01-2011, 21:39
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
How to wire REED switchs??
Hello,
can someone give a quick explanation on how to wire the reed switches to the control system?
Thank you
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 31-01-2011, 23:06
Re: How to wire REED switchs??
Use a PWM cable.
Wire one wire to white (signal)
Wire the other wire to black (ground)
Do NOT use the red 5v wire.
The other end of the PWM cable plugs into one of the set of 14 Digital IO pins on the Digital Sidecar.
Unread 31-01-2011, 23:07
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
I don't think there is any connection difference for a reed switch from any other switch of the same electrical type. e.g. NO, NC, SPST SPDT DPDT The actuation by magnetic field is the main distinction for this type switch.
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
Unread 01-02-2011, 00:31
Mk.32's Avatar
AKA: Mark
So the red wire of the reed switch goes to signal and the black wire goes to the (-) on the Digital Sidecar?
Unread 01-02-2011, 09:18
Yes
