Go to Post Fame... Fortune... Bleh I'm inspired and thats all that matters to me - Noah Melamed [more]
Unread 31-01-2011, 23:34
rahilm's Avatar
rahilm rahilm is offline
AKA: Rahil Mehta
FRC #0668 (The Apes of Wrath)
rahilm has a spectacular aura aboutrahilm has a spectacular aura about
Re: powering Banebots RS395
Originally Posted by Joe Ross View Post
What rule makes you think this is legal?
<R48> All electrical loads (motors, actuators, compressors) must be supplied by an approved power regulating device (speed controller, relay module, or Digital Sidecar PWM port) that is controlled by the cRIO-FRC on the ROBOT.
A. Each CIM motor and Fisher-Price motor must be connected to one and only one approved speed controller. These motors must not be connected to relay modules.
D. Each other electrical load (motor or actuator) must be supplied by one and only one approved speed controller, or one and only one relay module.
Only CIMs and FPs have to have a speed controller. All other motors (i.e. RS-395) can be controlled by a relay.
<R39> All active PD Board branch circuits shall be protected from overload with an appropriate value auto resetting Snap Action circuit breaker (from the KOP or identical equivalent).
B. Each relay module branch circuit must be protected with one and only one 20-amp circuit breaker on the PD Board. No other electrical load can be connected to the breaker supplying this circuit.
This does say that each relay must have a 20A breaker on the PD, but nothing about on the relay itself.
Team 668 - Apes of Wrath - 2008-2011
Team 668 - Apes of Wrath - 2011-Present (Mentor)
