Go to Post I'm absolutely certain there are simpler ways of accomplish the same things. I'm simply not the best that FIRST has to offer in this regard and part of what drives me to keep going is the desire to get better at achieving an elegant solution with as few superfluous processes as possible. - Madison [more]
Unread 01-02-2011, 00:07
NyCityKId's Avatar
NyCityKId NyCityKId is offline
That Weird Kid
AKA: Andre Dunkley
FRC #1601 (Quantum Samurai)
NyCityKId is a splendid one to beholdNyCityKId is a splendid one to beholdNyCityKId is a splendid one to beholdNyCityKId is a splendid one to beholdNyCityKId is a splendid one to beholdNyCityKId is a splendid one to beholdNyCityKId is a splendid one to beholdNyCityKId is a splendid one to behold
Send a message via AIM to NyCityKId
Tetrix Gearbox Help
So today I finally got a chance to take apart the Tetrix gearbox after finding out that it wasn't and integral part of the motor... and to my surprise it wasn't a bunch of planetary gears like i thought but a bunch or spur gears. I tried and failed to rearrange the gears and/or remove a gear and it didn't work out. I was wondering how other teams were handling the gearboxes on there tetrix motors?
Unread 01-02-2011, 00:33
Brandtlamonte Brandtlamonte is offline
FRC #2080
Brandtlamonte is an unknown quantity at this point
Re: Tetrix Gearbox Help
I'd also like to know. Plus can anyone show a diagram of a setup where the output will be the same/near the input?
Unread 01-02-2011, 00:39
rocketeer1 rocketeer1 is offline
FRC #2993
rocketeer1 is an unknown quantity at this point
The motor will probably need to be geared down a bit, so it would be even better if it was possible to mod the gear box to about a 1:20 ratio (vs the 1:52 it is originally, right?).
Unread 01-02-2011, 08:48
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
Have you seen this? http://www.chiefdelphi.com/forums/sh...&postcount=142
Unread 01-02-2011, 10:49
NyCityKId's Avatar
That Weird Kid
AKA: Andre Dunkley
Originally Posted by Dad1279 View Post
Thanks a lot. I haven't really gone through that thread because of the sheer number of post. I guess I'll have to buckle down and start reading.
Unread 24-02-2011, 23:58
Hurband Hurband is offline
AKA: Dick Hurban
FRC #5837 (Unity4Tech)
Hurband is a glorious beacon of lightHurband is a glorious beacon of lightHurband is a glorious beacon of lightHurband is a glorious beacon of lightHurband is a glorious beacon of lightHurband is a glorious beacon of light
Talking Re: Tetrix Gearbox Help
The Tetrix gearbox can be easily changed from 52:1 (as received) to either 31.2:1 or10.4:1.
When you take off the gearbox end plate by carefully grinding, using a dremel, the 3 tabs you will notice 3 compound gear sets each on a separate shaft. 2 are identical.
If you connect (stack) the 2 identical gearsets by lets say by soldering them you will find that by some axial endplay adjustement these will fit nicely and you will have a 31.2:1 gearbox. You may need to push the motor drive gear onto the motor shaft and even grind down its length a little bit.
To get a 10.4:1 reduction stack and attach one of the intermediate gearsets with the input and with even less axial adjustment you will have a 10.4:1 reduction.
The motors can drive a 4 inch wheel with 31.2:1 reduction and with light enough bot you can climb in ~ 2.5 seconds.
I calculate that with 10.4:1 and 2 inch wheels you can climb under 2 seconds.
Unread 24-02-2011, 23:59
AKA: Dick Hurban
The motors can each drive a 4 inch wheel with 31.2:1 reduction and with light enough bot you can climb in ~ 2.5 seconds.
Unread 25-02-2011, 00:21
Chris is me's Avatar
AKA: Pinecone
Throw the gearboxes away. They're terrible.
Unread 25-02-2011, 00:23
bhsrobotics1671's Avatar
bhsrobotics1671 bhsrobotics1671 is offline
Andrew Nabors
AKA: Andrew Nabors
FRC #1671 (Buchanan Bird Brains)
bhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to behold
and then do what?
Buchanan Bird Brains - FRC Team 1671
2015 FIRST World Champions
118, 1678, 1671, 5012
Unread 25-02-2011, 00:42
Originally Posted by bhsrobotics1671 View Post
and then do what?
Let the motor loose.
Unread 25-02-2011, 01:07
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
Or to be more specific, use a smaller wheel as your gear down stage.
Unread 25-02-2011, 05:52
AKA: Pinecone
I wouldn't call it a "wheel" anymore.
And that's all the hints I'm giving.
Optionally, if you want to use a wheel, you can take the transmission and knock several stages out. Keep just the final 40 tooth gear and the brass gear stage. It's pretty easy to make them line up and mesh.
Even the simple addition of grease will make your gearboxes better.
Unread 04-03-2011, 03:18
TerryS's Avatar
TerryS TerryS is offline
FRC #2445 (RoboKap)
TerryS is an unknown quantity at this point
We tried soldering two of the gearsets together, but we couldn't get the solder to stick. Tried 60/40 rosin core and silver bearing acid core. Do you need to use a special flux or do some special surface prep to be able to solder them together?
