Go to Post My team does what works for my team. Let your team do the same. - Alexa Stott [more]
Unread 29-01-2011, 15:00
iNiLz iNiLz is offline
no team (None)
iNiLz is an unknown quantity at this point
Programming Mecanum?
Our team decided to use mecanum wheels this year and we've used java last year. I'm a bit familiar with java but I can't seem to find a way to approach programming mecanum. I checked out the library but I can't seem to understand. Does anyone have a simple or pseudo program for mecanum they can share?
Unread 29-01-2011, 15:08
Re: Programming Mecanum?
Could you articulate in a bit more detail what you don't understand about the library support for mecanum? You'll get better-targeted answers if you do that.
Unread 29-01-2011, 15:50
FirebearBenD's Avatar
FirebearBenD FirebearBenD is offline
FRC #2846
FirebearBenD is an unknown quantity at this point
Under public class RobotMain extends IterativeRobot,
RobotDrive m_drive;
Under public void RobotInit
m_drive = new RobotDrive(m_frontLeft, m_rearLeft, m_frontRight, m_rearRight); // those reference the motors declared in another section of the code
Under public void TeleoperatedPeriodic
m_drive.mecanumDrive_Cartesian(-1 * m_rstick.getX(),-1 * m_rstick.getY(), -1 * m_lstick.getX(), 0); //m_rstick and m_lstick are just joysticks
That's the code we're using right now. Cartesian is much simpler than Polar, because then you don't have to deal with the annoying trigonometry with polar coordinates. m_rstick and m_lstick are just joysticks. So, based on what we get for input from our joysticks, we can control forward/backward, strafe left/right, and turn clock/counter-clockwise. The rest of the code has been done by the WPI. Sorry if this doesn't help.
Unread 01-02-2011, 00:13
Patrick Chiang Patrick Chiang is offline
Programming
FRC #3070 (Team Pronto)
Patrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to all
You COULD do this:
/* Simulated tank drive controls for mecanum wheels */
magnitude = (leftStick.getMagnitude() + rightStick.getMagnitude()) / 2;
direction = (leftStick.getDirectionDegrees()+rightStick.getDirectionDegrees()) / 2;
rotation = (leftStick.getY() + rightStick.getY()) / 2;
driveRobot.mecanumDrive_Polar(magnitude, direction, rotation);
^ We did it like this because our driver specifically asked for these controls. He has driven tank drive for two years, and I guess old habits are hard to change.
You SHOULD do this:
magnitude = leftStick.getMagnitude();
direction = leftStick.getDirectionDegrees();
rotation = rightStick.getX();
^ This is what we call the FPS drive system (aka. xbox controller style). Left joystick controls w,a,s,d (forward, back, left, right) and diagonal movements. Right joystick controls rotation.
Unread 03-02-2011, 16:01
General25 General25 is offline
FRC #3352
General25 is an unknown quantity at this point
I have the same question, execpt for Labview. i can't figure how to put the motors in the Begin.vi and how to incoorpoate it into Telop. This is my first time changing our robot to mecanum
Unread 03-02-2011, 20:53
Robby Unruh's Avatar
Robby Unruh Robby Unruh is offline
*insert random dial-up tone here*
FRC #3266 (Robots R Us)
Robby Unruh will become famous soon enough
Our team is simply using arcade drive, since we've been having trouble with both the Polar and Cartesian driving. We have a toggle button that inverts the motors to strafe.
@General25:
You'd probably get better answers in the Labview section, since this is Java.
[Robots R Us #3266]
2015: Georgia Southern Classic (Winners / Thanks 1319 & 1648!), Queen City
2014: Crossroads, Queen City
2013: Buckeye, Queen City, Crossroads
2012: Buckeye, Queen City
2011: Buckeye
2010: Buckeye
Unread 04-02-2011, 18:11
FRC #3352
@General25:
You'd probably get better answers in the Labview section, since this is Java.[/quote]
sorry, just searched for mecanum and programing
Unread 07-02-2011, 07:04
I've had a little problem programming the mecanum wheels myself. In my post before I said I had inverted the motors to strafe. Well, turns out that makes a nasty ugly strafe. Anyone have tips regarding how to actually program a strafe with arcade drive?
Thanks.
here's our current code:
if(joystickL.getTrigger() && state == 0) {
    robotDrive.setInvertedMotor(frontLEFT, true);
    robotDrive.setInvertedMotor(rearRIGHT, true);
    // robotDrive.setInvertedMotor(frontRIGHT, false);
    // robotDrive.setInvertedMotor(rearLEFT, false);
    this.state = 1;
} else if(joystickL.getTrigger() && state == 1) {
    robotDrive.setInvertedMotor(frontLEFT, false);
    robotDrive.setInvertedMotor(rearRIGHT, false);
    this.state = 0;
[Robots R Us #3266]
2011: Buckeye
2010: Buckeye
Unread 07-02-2011, 09:18
Yes. There's an explanation here.
Unread 07-02-2011, 10:40
Thanks for the link. I'm still a little confused here, though.
Could you please explain how I'm supposed to use forward/backward/clockwise in the drive train programming?
[Robots R Us #3266]
2011: Buckeye
2010: Buckeye
Unread 07-02-2011, 11:32
That is explained on the second page:
front_left = forward + clockwise + right;
front_right = forward - clockwise - right;
rear_left = forward + clockwise - right;
rear_right = forward - clockwise + right;
// Finally, normalize the wheel speed commands
// so that no wheel speed command exceeds magnitude of 1:
max = abs(front_left);
if (abs(front_right)>max) max = abs(front_right);
if (abs(rear_left)>max) max = abs(rear_left);
if (abs(rear_right)>max) max = abs(rear_right);
if (max>1)
{front_left/=max; front_right/=max; rear_left/=max; rear_right/=max;}
// You're done. Send these four wheel commands to their respective wheels
front_left, front_right, rear_left, rear_right are the commands to send to each mecanum wheel.
If that's not what you were asking, please clarify your question and I'll try again.
Unread 08-02-2011, 08:10
if (max>1)
Okay, thanks again. So I just send those wheels in the drive train like so:
RobotDrive driveTrain = new RobotDrive(front_left, rear_left, front_right, rear_right);
Then invert the motors like I've been doing, or...?
[Robots R Us #3266]
2011: Buckeye
2010: Buckeye
Unread 08-02-2011, 08:24
Without knowing how you have your motors wired I cannot tell you whether or not you need to invert them.
I can tell you this: If your motors are wired so that when you give them a +1 command they go in the "forward" direction, then no inverting is required.
I recommend that you put the robot up on blocks and push the joystick(s) straight forward. If all four wheels spin in the "forward" direction, you're good to go. If not, then invert any motor that is spinning backwards.
Unread 08-02-2011, 10:32
omalleyj omalleyj is offline
AKA: Jim O'Malley
FRC #1279 (Cold Fusion)
omalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to behold
No, RobotDrive takes SpeedControllers in its constructor, not actual values. The example was giving you numbers to pass directly to your Jaguars. The sum total of the algorithm and motor control make your own robot drive method, you don't need the wpilibj version.
Unread 10-02-2011, 01:56
no team (None)
Sorry for the late reply.
So far this is what I currently have done and understand well.
import edu.wpi.first.wpilibj.SimpleRobot;
import edu.wpi.first.wpilibj.Compressor;
import edu.wpi.first.wpilibj.GenericHID;
import edu.wpi.first.wpilibj.Gyro;
import edu.wpi.first.wpilibj.Victor;
import edu.wpi.first.wpilibj.Timer;
import edu.wpi.first.wpilibj.Jaguar;
import edu.wpi.first.wpilibj.RobotDrive;
//Program
public class RobotTemplate extends SimpleRobot {
    //Drive Program
    RobotDrive drive = new RobotDrive(1, 3, 2, 4);
    //Joystick
    private Joystick leftStick = new Joystick(1);
    //private Joystick rightStick = new Joystick(2);
    //Autonomous Program
    public void autonomous() {
    //Teleop
    public void operatorControl() {
    getWatchdog().setEnabled(true);
        //WatchDog Enabled //Infinite Loop
        while (isEnabled() && isOperatorControl()) {
            getWatchdog().feed();
            drive.mecanumDrive_Polar(leftStick.getDirectionDegrees(), leftStick.getMagnitude(), leftStick.getTwist());
            Timer.delay(0.005);
I haven't tested it yet but will tomorrow.
Once I figure out how Cartisian works, I'll update the code.
Now to figure out the gyro and encoder.
