Go to Post As a programmer, I am trying to use more 0's than 1's to save weight. - Jared Russell [more]
Unread 01-27-2011, 08:57 PM
hornetshornets's Avatar
hornetshornets hornetshornets is offline
FRC #1816
hornetshornets is an unknown quantity at this point
Exclamation Cannot use RobotDrive!
We are programming with Java as an option this year, and whenever we call the RobotDrive class, we get an error stating:
"Cannot find symbol:
class RobotDrive"
What should we do?
All help is greatly appreciated!
- Team 1816 -
A man once turned his car into the shop with a complaint that read “Unfamiliar noise from engine.” The next day, the car was ready for him. The engineer’s logbook entry read “Ran engine continuously for four hours. Noise now familiar.”
Unread 01-27-2011, 09:10 PM
Alexander Meyer Alexander Meyer is offline
FRC #2358 (Bearbotics)
Alexander Meyer is on a distinguished road
Re: Cannot use RobotDrive!
Have you imported the RobotDrive class? The default examples only import the IterativeRobot or SimpleRobot classes, nothing else. You could import all the WPILibJ classes in one fell swoop with this line:
import edu.wpi.first.wpilibj.*
Unread 02-01-2011, 12:06 AM
Patrick Chiang Patrick Chiang is offline
Programming
FRC #3070 (Team Pronto)
Patrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to all
The Source > Fix Imports function in netbeans is cool. Just use it all the time when you see random yellow lightbulbs in your code.
Unread 02-01-2011, 08:38 AM
Egg 3141592654's Avatar
Egg 3141592654 Egg 3141592654 is offline
Now a mentor, always a student
FRC #0810 (Mechanical Bulls)
Egg 3141592654 is on a distinguished road
If the asterisk at the end of your wpilib import call doesn't work, use the netbeans autofill feature to add RobotDrive class as its own import. Whenever I have import problems, I just add the individual class in my import field. Hope you don't have to do that though, it gets a bit tedious when your team uses a lot of components which require a lot of classes.
"The answers to the book of life are not found in the back." Charlie Brown
Software Mentor - Team Apex Robotics 5803
Lead Programmer - Team 810 Mechanical Bulls '09-'11
