Go to Post I've got it! INFLATABLE clown fish!!!! - dlavery [more]
Unread 31-01-2011, 13:44
Re: Minibot Questions
As to threaded rod, only if you can make it from...
H. Raw aluminum sheet, 90° angle, u-channel, tube, bar, that is not sold in pre-perforated or pre-punched form.
I would suspect that you could get round Al bar and thread it. Whether you can get it to fit into the Minibot volume and still come down enough to get the Minibot easily is a little trickier.
Unread 01-02-2011, 00:06
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
I suggest teams put a hook or ring on their robot that gives an obvious place for the Field Personnel to grab the minibot. You should do this even if you are planning to have the robot bring itself down because things don't always go according to plan.
ChrisH
Christopher H Husmann, PE
"Who is John Galt?"
Unread 01-02-2011, 00:15
Vikesrock's Avatar
Vikesrock Vikesrock is online now
Team 2175 Founder
AKA: Kevin O'Connor
GDC decided it's a fastener:
http://forums.usfirst.org/showthread.php?t=16667
Unread 01-02-2011, 03:04
Nemisis's Avatar
Nemisis Nemisis is offline
Frame/Body/Motors
FRC #2389 (S.T.O.R.M.)
Nemisis will become famous soon enough
Hello Everyone! Does anyone have any ideas whatsoever abut the deployment of the Mini-bot? any advice or ideas from any team would be treated with the utmost appreciation!! Thank You!
Team 2389
RHS Senior 2011
Unread 01-02-2011, 11:03
JB987 JB987 is offline
AKA: Joe Barry
FRC #0987 (HIGH ROLLERS)
JB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond repute
Team 2389
Go to Youtube, type in FRC minibot and observe closely
Unread 01-02-2011, 14:15
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Couldn't threaded rod be considered a mechanical fastener?
Unread 01-02-2011, 14:29
At the time I made that post, it was unclear. Someone asked Q&A, and it is considered a fastener by the GDC. Therefore, it is a fastener for FRC purposes (whether or not is is actually a fastener).
Unread 01-02-2011, 18:13
lonski lonski is offline
FRC #2486
lonski is an unknown quantity at this point
does annyone know if there are any spefications on the aluminum sheet. ex. thickness, limited amount. and does anyone know if we can use pvc sheet or does it have to be tubing
Unread 01-02-2011, 18:55
Mike Wittman's Avatar
Mike Wittman Mike Wittman is offline
Plastic Man
FRC #1714 (More Robotics)
Mike Wittman is an unknown quantity at this point
Not if you do it right. Not being entirely certain of the method there, I'd say to find 1714 (or Chris is me) and ask them.
Steel cable: Not legal on the Minbot. You can use non-metallic rope or cord.
Henry, check the Q&A I linked to again.
Polycarbonate can be cold bent, and in most cases it will not break. It can be bent in an apron break or a press break. If you are going to bend it over onto itself you will need to stress release the material with heat. Many hobbyists do it with a heat gun.
If you are looking for a spring tension, you could stack layers of different thickness to create a leaf spring. This will allow you to play with different tensions. It is very unlikely that you will break Polycarbonate using it this way.
Mike
Tie two birds together, though they have four wings they cannot fly
www.morerobotics.org
Learn More, Give More, Be More
Unread 01-02-2011, 19:37
The GDC answered that anything marketed as sheet is sheet. The rule in other words reads PVC pipe or fittings CPVC pipe or fittings. Sheet PVC is not part of the rule.
Unread 04-02-2011, 17:53
E2207 E2207 is offline
FRC #2207
E2207 is an unknown quantity at this point
Is it possible that we can have anotehr FRC team with a water jet cutter to cut our minibot sheet metal on a CAD file?
Unread 04-02-2011, 18:22
Yes,
There is no restriction in the minibot rules that prevents you taking advantage of someone's watergenerosity.
Unread 04-02-2011, 18:44
FRC #2207
Anyone generous out there?
Unread 04-02-2011, 20:25
Brian Ha's Avatar
Brian Ha Brian Ha is offline
Teh Ha Kid
FRC #0302 (Team 302)
Team Role: Driver
Brian Ha has a spectacular aura aboutBrian Ha has a spectacular aura aboutBrian Ha has a spectacular aura about
Umm, we have our wheels basically drop their power or however you would actually word it, and then drop. We plan on putting some foam underneath it, both the minibot and the deployment system because the first time we did it, some things fell out, then we did it again without fixing it, and some more things came off. So you might want to have it free drop, but have some sort of thing to either cushion its fall or prevent it from hitting the ground intensly hard.
Starcraft 2 Hit me up Cheese 972, or join the FRC chat room ingame
Unread 05-02-2011, 01:58
Umm... Can someone tell me where to find "foam" of some form in <R92>?
Deployment system, go for it. Minibot, start thinking creatively. Hmmm... stretch surgical tubing on the bottom of the Minibot, maybe?
