Go to Post If you are content with where you are, you have celebrated the right things. If not, perhaps it is time to reconsider... what’s most important to you. - StephLee [more]
Unread 30-01-2011, 23:45
drakesword drakesword is offline
AKA: Bryant
FRC #0346 (Robohawks)
drakesword is on a distinguished road
useing UV
Haven't found it anywhere in the rules but would the use of UV light be legal?
Were thinking of 2 or 3 LEDs. I know that UV shows up VERY well on camera(to the point that it could saturate the image)
Unread 31-01-2011, 00:42
samir13k samir13k is offline
AKA: Samir Shaikh
FRC #4329
samir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant future
Send a message via AIM to samir13k Send a message via MSN to samir13k
Re: useing UV
I believe you're thinking of IR and i dont see why not, but im not the rule book
Unread 31-01-2011, 02:01
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Re: useing UV
Ultraviolet LEDs aren't such a great idea: many are of a wavelength and intensity that can be harmful with direct exposure, and since the human eye's blink reflex doesn't work on UV, you don't really know when you're being exposed. They're not illegal, but they would be subject to the usual safety rules.
As for infrared—which does show up on CCD cameras—it's allowed. (Infrared at an intensity high enough to harm you would be something to behold...if only you could see it.)
And by the way, <R02> says you can't include anything intended to interfere with other robots' vision systems. <G30> says you get a red card if you try.
Unread 31-01-2011, 07:18
DonRotolo's Avatar
Back to humble
FRC #0832
Re: useing UV
3 or 4 watts is enough to hurt you. The iris of the human eye does not have a response to IR like it does to visible light. But you won't see that kind of light with an LED...
Unread 01-02-2011, 10:09
AKA: Bryant
Re: useing UV
I was thinking with the power output of the LED at a great distance as the robot to the judges/spectators it shouldn't be a problem. Doesn't plexi block uv?
Unread 01-02-2011, 11:09
Re: useing UV
Bryant,
You are sitting right next to it in the pit, while working on it at home and you are exposing everyone that the robot drives by during a match. That is, field resetters, refs, FTA, FTAA, judges, and me. There is a reason those guys on CSI and at the dentist office wear special glasses. Please re-engineer to use something other than UV radiating devices.
Unread 01-02-2011, 11:44
Re: useing UV
<R02> also says that "ROBOT parts shall not be made from hazardous materials, be unsafe, or cause an unsafe condition. Items specifically prohibited from use on the ROBOT include (but are not limited to): [list]". If in the judgment of the inspectors, refs, and other similar field personnel, your robot is doing any of the above, you will be found in violation of <R02>, regardless of any of the specific points not covering it.
And Al is an inspector.
Unread 01-02-2011, 16:17
AKA: Bryant
Re: useing UV
I gotcha. I'm not saying we are using it just trying to find out if it was an option. I know UV at certain levels or high enough wavelengths could be dangerous but didn't know if 1 or 2 leds of the near uv would be bad. Seeing as it is questionable we will stay away from it.
I have asked a couple of the local inspectors this past weekend who gave answers of being unknown. (actually one said he didn't see it as being an issue)
So for an alternative we shall look at a large number of red and blue leds.
Unread 01-02-2011, 17:23
Re: useing UV
Bryant,
I suspect that the inspectors you talked with were unaware of the issues. Most people are not familiar with UV radiation and it's effects. It is not something that we have discussed in inspector training.
There are LEDs and then there are LEDs. Since we can't see the radiation, we can't tell if they are super bright or merely bright.
Unread 01-02-2011, 18:06
Re: useing UV
What do you intend to do with these LEDs?
If they are to be used as illumination for the retroreflective tape, keep in mind that you probably don't want to make it very bright. The tape itself is extremely reflective. A too-bright light will completely saturate the camera, which will keep you from being able to match a particular color.
Our testing gives us useful results from a dozen semi-bright red LEDs behind a layer of mylar used as a diffuser. We're going to try again with (less-bright) green ones, because using a red color target we've seen undesired recognition of robot bumpers.
Unread 02-02-2011, 09:17
AKA: Bryant
Re: useing UV
@alan
We were going to use maybe 12-18 half and half.
Turn brightness down to 0, white balance off and only go for the bright spots.
From the bright spots filter out anything other then purple.
@al
Just curious. Does blacklight not constitute as near UV? Not to sound like a jerk but blacklights have typically been deemed safe as far as UV exposure went although still having the effects of such (e.g. phosphorescence)
Unread 02-02-2011, 12:00
Re: useing UV
Yes, blacklights are UV but they produce very little when in use. Since they are not a point source, the energy is spread out and some of it is visible. The UV source for erasing EPROMs is a higher energy and it is protected so that you cannot be in the radiation. Remember that tanning salons (tanning tables) require that you wear eye protection and that is also UV in nature.
Unread 02-02-2011, 12:08
AKA: Bryant
Re: useing UV
Not to drag this on or anything but if we were to say diffuse 2 leds with the same wavelength or longer through a tube would you have an issue with it or is it still too questionable.
I understand the dangers with shorter wavelengths or a point source but for near UV at low power diffused like a blacklight I don't see the issue.
Unread 02-02-2011, 18:57
Re: useing UV
Bryant,
We are answering in more general terms because the original post doesn't specify output power, output spectrum or beam width. There are so many devices, we cannot give you a simple answer. I did a search for both blacklight bulbs and UV LEDs including flashlights. There were no associated warning labels on the blacklight bulbs. The flashlights carried a warning to use special glasses and to never point the light into someone's eyes. That should be sufficient to question their use on a robot in close proximity to people.
Unread 02-02-2011, 20:48
548swimmer's Avatar
548swimmer 548swimmer is offline
CAD Leader
AKA: Alec Wagner
FRC #0548 (Robostangs)
Team Role: CAD
548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of
Re: useing UV
I've had good luck getting UV reaction out of 470nm blue LED's. I installed them for my friends climbing wall in his garage, and all of the fluorescent holds glow as if they were under a black light. The neat thing about these LED's is that they are still solidly in the visible spectrum, so the blink reflex occurs. This wont be as significant as UV LED's, but should help.
My religion is physics, it can explain everything.
WINNER -- 2011 Waterford District
District Chairman's -- 2011 Waterford District
Finalist -- 2011 Ann Arbor District
State Chairman's -- 2011 Michigan State Championship
Quarter-finalist -- 2011 Galileo
2011 Championship -- Highest Ranking Score
