Go to Post So we can bring 6x more to the Lunar Regional than all other regionals? no fair to those not going! - BBray_T1296 [more]
Unread 01-02-2011, 10:38
zebrabots zebrabots is offline
FRC #2909
zebrabots is on a distinguished road
Can we use a wireless transmitter to turn on the power of our minibot?
Unread 01-02-2011, 11:33
Re: Can we use a wireless transmitter to turn on the power of our minibot?
Sorry, <R52> prohibits any wireless communication to, from, or within the ROBOT besides the D-Link DAP-1522.
I don't think a wireless receiver is one of the permitted MINIBOT components, either.
Unread 01-02-2011, 11:35
Consider this: the NXT's Bluetooth function must be disabled (<R92-E>), and none of the other items on the list can really function as a receiver (FTC's Samantha module is not FRC-legal).
So there is no way to get a wireless transmission to the Minibot and have it received.
Unread 01-02-2011, 11:46
Though RF is out, it might be okay to use an electromagnet on the HOSTBOT and a reed switch on the MINIBOT. But what's wrong with flipping a physical switch using a servo or pneumatic actuator?
Unread 01-02-2011, 12:16
TD912 TD912 is offline
AKA: Chris Leung
FRC #1989 (Viking Robotics)
TD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud of
The rules don't allow for any kind of wireless transmitter on the minibot. You can use an NXT module on the minibot, but the wireless Bluetooth functions have to be disabled.
We are likely going to use a limit switch that came in the KOP. Limit switches are in the allowed list of minibot parts too.
Some limit switches look similar to this:
When the lever on the side of the switch is held down, the circuit will be open. When the minibot is deployed, some mechanism on the host robot should release the lever, which completes the circuit and activates the minibot.
Zip-ties, hot glue, and duct tape.
2008 New York City Regional Champions - (41/555/1989)
2009 Brunswick Eruption 8 Finalists - (1989/56/1807)
2010 PARC XIII Champions - (25/341/1989)
Over The Bump
Unread 01-02-2011, 13:04
If using limit switches to route 12v power, make sure they are rated for the kind of amperage they will have to pass through.
Unread 01-02-2011, 15:09
While we are on the subject...
A switch rated for 12 amps @ 48 volts does not equate to 48 amps at 12 volts. It means the switch can pass 12 amps when closed but will not arc over at 48 volts when open. 12 amps DC is just that.
