Go to Post I think the only way I'd die from posting on CD is from my wife killing me. - Koko Ed [more]
Unread 29-01-2011, 15:41
baronep's Avatar
baronep baronep is offline
Student President
FRC #2848 (Jesuit All-Sparks)
baronep is on a distinguished road
Andy mark mechanum problem
So my team is having some issues with the Andy Mark 6" mechanums. They are in the correct orientation (X from the top) and they spin in the correct direction when they are on jacks, but they refuse to strafe side to side. Instead they follow a diagonal curving path. (Forward and to the left for a left strafe and backward and to the right for a right strafe).
Things we have tries:
Calibrating the Jags
Testing the output voltage on jags
attaching extra batteries to try different weight distributions (but i'm not sure the weight distribution is not the problem)
the rollers seem to roll fine
one of the mechanums wobbles when it runs and another is at a slight angle in relation to the frame (<10 degrees off)
Has anyone experienced this problem before?
Thanks
-baronep
Unread 29-01-2011, 15:52
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
Re: Andy mark mechanum problem
When the robot sits on a level surface, are all the wheels equally touching the ground? Could the frame be twisted?
Unread 29-01-2011, 18:46
NyCityKId's Avatar
NyCityKId NyCityKId is offline
That Weird Kid
AKA: Andre Dunkley
FRC #1601 (Quantum Samurai)
NyCityKId is a splendid one to beholdNyCityKId is a splendid one to beholdNyCityKId is a splendid one to beholdNyCityKId is a splendid one to beholdNyCityKId is a splendid one to beholdNyCityKId is a splendid one to beholdNyCityKId is a splendid one to beholdNyCityKId is a splendid one to behold
Send a message via AIM to NyCityKId
If the frame isn't warped then maybe its a problem with the gearboxes not being broken in properly... I can't think of anything else since you say that the wheels spin the correct directions. The last and final thing you might want to try is switching joysticks. However, the most likely cause is an imbalance of force being transmitted to the surface since the mecanums operate on the principal of vectors
Unread 29-01-2011, 20:37
conroym conroym is offline
Team Lead
AKA: Matt
FRC #2023 (PiraTech Robotics)
conroym is an unknown quantity at this point
Send a message via Yahoo to conroym
if you are running on a flat frame, or a out of square frame--I expect you are experiencing a torquing issue with the frame when power is applied causing frame warpage not visible to the eye but causing all wheels to not contact the the floor evenly--have seen this.
Unread 29-01-2011, 20:48
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
Also, make sure that your rollers have some same level of movement. Some may be tighter than others. This might cause some of the problems you describe.
Unread 29-01-2011, 21:54
Hawiian Cadder's Avatar
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
cims gain a bias in one direction after a year or two of use, if your cims are 2 years old i have found 12-15% difference between forward and backward, if you cannot get new cims, you might have to account for them not being the same forward and backward.
Unread 30-01-2011, 01:29
kylelanman's Avatar
kylelanman kylelanman is offline
Programming Mentor
AKA: Kyle
FRC #2481 (Roboteers)
kylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to all
We have found the Jags are biased in one direction. Reverse the polarity of the motor leads not the power leads on the Jag and account for it in the code.
"May the coms be with you"
Is this a "programming error" or a "programmer error"?
Unread 30-01-2011, 02:44
Chris is me's Avatar
AKA: Pinecone
This isn't true - and if it is, calibrating them would have fixed that.
Unread 30-01-2011, 02:54
AKA: Isaak
Team Role: CAD
the cims are bias, the jags are perfect, the rotor in the cims magnetizes the more you use them, so if you have old cims, the don't spin with as much power in one direction.
Unread 30-01-2011, 03:12
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
Thanks
-baronep
Sounds like you know what the problem is. It probably is one of these.
Another option, when i drove mecanum last year, I first thought that I was pushing straight sideways on the joystick, but was not. This could be it aswell.
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
Unread 30-01-2011, 08:49
Alpha Beta's Avatar
Alpha Beta Alpha Beta is offline
Strategy, Scouting, and LabVIEW
AKA: Mr. Aaron Bailey
FRC #1986 (Team Titanium)
Alpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond repute
We used mecanum in 2008. It helped to have each wheel in a spring loaded suspension so they always had the same pressure on the floor regardless of the squarness of the frame (or the levelness of the floor).
http://www.chiefdelphi.com/media/photos/30031
http://www.teamtitanium.org/media/20.../target26.html
http://www.teamtitanium.org/media/20.../target28.html
PS. It was the fastest robot we've ever built.
Regional Wins: 2016(KC), 2015(St. Louis, Queen City), 2014(Central Illinois, KC), 2013(Hub City, KC, Oklahoma City), 2012(KC, St. Louis), 2011(Colorado), 2010(North Star)
Regional Chairman's Award: 2014(Central Illinois), 2009(10,000 Lakes)
Engineering Inspiration: 2016(Smoky Mountain), 2012(Kansas City), 2011(Denver)
Dean's List Finalist 2016(Jacob S), 2014(Cameron L), 2013(Jay U), 2012(Laura S), 2011(Dominic A), 2010(Collin R)
Woodie Flowers Finalist 2013 (Aaron Bailey)
Championships: Sub-Division Champion (2016), Finalist (2013, 2010), Semifinalist (2014), Quaterfinalist (2015, 2012, 2011)
Other Official Awards: Gracious Professionalism (2013) Entrepreneurship (2013), Quality (2015, 2015, 2013), Engineering Excellence (Champs 2013, 2012), Website (2011), Industrial Design (Archimedes/Tesla 2016, 2016, 2015, Newton 2014, 2013, 2011), Innovation in Control (2014, Champs 2010, 2010, 2008, 2008), Imagery (2009), Regional Finalist (2016, 2015, 2008)
Unread 01-02-2011, 12:21
CMills CMills is offline
FRC #1529 (CyberCards)
CMills is an unknown quantity at this point
Are team is using it this year.
Some keys that we have found:
-Evenly distribute weight
-Make sure the code supports straffing
-Make sure everthing is fastened properly (the wobble could be binding when trying to strafe.)
This and a number of minor tweaks that can be pretty self-intuitive should get you back on track.
