Go to Post Inspiration and recognition does not equal "advanced shop class". What's better for your team is not better for all teams. Remember that. - DonRotolo [more]
Unread 11-01-2010, 17:58
DinerKid's Avatar
DinerKid DinerKid is offline
AKA: Zac
FRC #1768 (Nashoba Robotics)
DinerKid is a glorious beacon of lightDinerKid is a glorious beacon of lightDinerKid is a glorious beacon of lightDinerKid is a glorious beacon of lightDinerKid is a glorious beacon of light
Mecanum Drive Killing Battery
Hey CD i am a member of team 1768. We have been toying with the idea of mecanum drive this year and have read tons of of threads here on CD about it. One thing that was brought to our attention today that we have never heard here on CD is that it kills your battery pretty quickly. It makes sense that driving 4 CIMs would kill the battery faster than two. What has your experience been with mecanum drive and power consumption?
Unread 11-01-2010, 18:08
,4lex S.'s Avatar
,4lex S. ,4lex S. is offline
University Mentor
AKA: Alex Strong
FRC #2702 (REBotics)
,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of
Re: Mecanum Drive Killing Battery
Although I have not run a mecanum drive, I have been involved with a holonomic (omniwheels), which shares pretty much all the characteristics. I do not recall any battery drain issues.
My former team ran 4 CIMs all the time (except last year) without a problem, so I wouldn't worry about it. Mecanums also have a relatively low coefficient of friction (because of the rolling), so they won't run into many power sucking situations (like tripping your breakers).
University of Waterloo Mechanical Engineering Class of 2014- 2B School Term
University of Waterloo Formula SAE Race Team 2010-Eternity
FRC 2702: REBotics 2011 Mentor ::: FRC 1006: Fast Eddie Robotics 2005-2009 Alumni ::: FLL 4050: 2004 Alumni
Unread 11-01-2010, 18:53
I don't know how you found out about this, but it isn't true unless the battery is faulty. 4 CIMs in the drive should last all match and then some on one battery, and throw in other motors and a compressor for good measure. One match shouldn't drain the battery.
We ran one in 2005 as a test, and never had an issue with the battery.
Unread 11-01-2010, 19:11
DinerKid's Avatar
AKA: Zac
I think what it really boils down to is how you are running for CIMs. obviously if you are stalling 4 CIMs you are at something like 428 amps, WAY over the breaker. If you can run all four at 15 amps each then you should fine from the graph we were looking at earlier.
I am still interested in hearing about other teams experiences with running 4 CIMs on drive preferably on a mecanum chassis but if not that is fine as well.
Unread 11-01-2010, 19:17
Pretty much right on. I don't remember exactly where on the curve you want to design for with CIMs, but you do want to design them right.
330 ran a 4-CIM drive between 2005 and 2008; I'm not sure about last year. No issues whatsoever with batteries (other than keeping them all charged during hours-long practice sessions in '07 and '08). All the robots were 6WD.
But, in 2005, the competition robot was designed to accept a mecanum drive. The Kitbot was equipped with that system for testing purposes; it didn't make it onto the competition robot. There were no battery issues on that robot.
Unread 11-01-2010, 19:56
DinerKid's Avatar
AKA: Zac
With that being said... did it work out in your situation that you were running the CIMs with the desired current and still running at a decent speed? obviously you can design the CIM's to run at any current but if doing that means you are going to drive at a snails pace then it is kind of pointless. Was the robot that you are talking about able to drive with average speed without drawing too much current or was it slow?
Unread 11-01-2010, 19:57
The mecanum robot was normal speed. The others were easily normal speed or fast. No breakers tripping, that I remember.
Unread 11-01-2010, 20:12
DiehardCybercard's Avatar
DiehardCybercard DiehardCybercard is offline
zaba do de da, FIRST
no team (AndyMark)
DiehardCybercard has much to be proud ofDiehardCybercard has much to be proud ofDiehardCybercard has much to be proud ofDiehardCybercard has much to be proud ofDiehardCybercard has much to be proud ofDiehardCybercard has much to be proud ofDiehardCybercard has much to be proud ofDiehardCybercard has much to be proud ofDiehardCybercard has much to be proud ofDiehardCybercard has much to be proud of
as an off season project my team built a t-shirt cannon. the cannon and assembly is mounted on a mechanism drive base. we have driven the drive base over 30 minutes on one charged battery. We've never had issues with battery life with 4 CIMS
Brett Heininger
AndyMark, Inc. Web & Media
Unread 11-01-2010, 20:31
J_Beth J_Beth is offline
AKA: Justin Beth
FRC #0935 (RaileRobotics)
J_Beth will become famous soon enoughJ_Beth will become famous soon enough
My former team (team 935) has made many robots that use a mecanum drive, and we have never ran into any problems with running out of power. during testing of our robots before competition we could run our robot for a good 5 minutes at full speed before we started having power loss issues. One charged battery should easily last one round, and be able to run your mecanum drive along with your other motors as well.
Unread 12-01-2010, 10:35
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
As others have said, running 4 CIM's shouldn't be a problem for a battery. The key is to monitor your current draw in testing, and any areas where it looks high at full speed you need to take a second look at - It means you probably have some unnecessary friction in your drive train somewhere (aka something is out of alignment).
Last year, we used two CIM's for a shooter. After the initial test and some adjustments, the current draw for those CIM's was cut in half!
Unread 16-01-2010, 22:30
Diner,
The are a variety of reasons that can cause high current in a mecanum drive.
1. The gear ratio you have chosen is too low and so the motors are not developing enough torque to drive. That puts the motor in near stall conditions.
2. Something is binding in the drive system. You may have left out a required spacer or something else is causing the wheels to bind.
3. Your design produces a lot of side load on the CIM motor shafts. These motors cannot handle side loads so any loading will cause high friction on the output shaft and eventual wearing of the motor bearings.
4. One or two of the motors are running in the wrong direction. This is especially evident if everything (current and speed) seems normal if you lift the robot off the floor. While it is off the floor note the direction each wheel is turning. If coupled in a two motor transmission, try disconnecting one motor on each side and see if the current is still high.
Without seeing your design it is hard to determine exactly what might be the problem.
Unread 31-01-2011, 18:14
chris janney chris janney is offline
FRC #3266
chris janney is an unknown quantity at this point
Last year we ran two motors for at least three matches. running four for a match won't be a problem, though if one was careful, he would have another battery ready to go for the next match.
Unread 01-02-2011, 14:22
Nemo's Avatar
Nemo Nemo is offline
Team 967 Mentor
AKA: Dan Niemitalo
FRC #0967 (Iron Lions)
Nemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond repute
Our robot from last year ran 8" mecanums directly from 12.75:1 toughboxes (cantilevered shafts, two of which definitely experienced some side loading) along with an air compressor. That thing can run a battery down in 10-15 minutes if you drive it continuously and use the pneumatics enough to keep the air compressor running. Even in that situation, we weren't particularly close to running out of power in one match.
Unread 01-02-2011, 14:26
joek's Avatar
joek joek is offline
Team Welder and CAD tech
FRC #2052 (KnightKrawler)
joek is an unknown quantity at this point
we have used mecanum every year except 2009 (and even then used 4 cims), and have never had battery issues with that, it is only the compressor and vacuums that drain batteries much, unless the battery is bad
2012 Record (13-2-0)
lake superior regional finalists- thank you WAVE (2826) and Blue Twilight (2220)
Unread 01-02-2011, 14:35
goldenglove002 goldenglove002 is offline
AKA: Alex Epstein
FRC #1311 (Kell Robotics)
goldenglove002 is a jewel in the roughgoldenglove002 is a jewel in the roughgoldenglove002 is a jewel in the rough
If you don't do it right, yes it will kill your battery. We tried mecanums for the first time last year and were lucky if the battery lasted through one match. Do it right and your golden, do it wrong and you'll really regret the choice of mecanum.
2011 Peachtree Regional Dean's List Recipient
2011 Peachtree Regional Kleiner Perkins Caufield & Byers Entrepreneurship Award
2011 Lemelson/MIT InvenTeams Grant
2010 North Carolina Regional Chairmans Award
2010 Peachtree Regional Kleiner Perkins Caufield & Byers Entrepreneurship Award
2010 SeaWorld Busch Gardens Environmental Excellence Award
2009 Peachtree Regional Chairmans Award
2008 Peachtree Regional Judges Award
crab drive vs. mecanum drive system superbotman Technical Discussion 33 06-01-2010 03:09
Mecanum Drive - Help Smoking_Gun Programming 22 04-12-2007 20:51
Mecanum Drive Technique Dan Petrovic Technical Discussion 9 16-08-2006 20:42
pic: Jester Drive:Mecanum Wheel Drive Train Ken Delaney 357 Technical Discussion 64 29-03-2006 22:16
