Go to Post There's a fine line between cockiness and confidence. Confidence is one of the major keys to success and happiness in life. As long as one can carefully stay on the right side of the line, staying connfident while remaining humble, and ego can be quite beneficial. - Karthik [more]
Unread 01-02-2011, 14:36
gyroscopeRaptor's Avatar
gyroscopeRaptor gyroscopeRaptor is offline
Registered ConfUser
AKA: Mark McGivern
FRC #3633 (Catalyst)
gyroscopeRaptor has a spectacular aura aboutgyroscopeRaptor has a spectacular aura about
2 jaguars with flashing red light
We have had 2 jaguars get red, flashing lights as soon as robot communication is established. We have used a multimeter to check the electrical readings in, and they are the same as the jaguar that is OK.
Any assistance would be appreciated.
Unread 01-02-2011, 15:09
plnyyanks's Avatar
Data wins arguments.
AKA: Phil Lopreiato
Re: 2 jaguars with flashing red light
jaguar status led codes:
LED State Module Status
Normal Operating Conditions
Solid Yellow: Neutral (speed set to 0)
Fast Flashing Green: Forward
Fast Flashing Red: Reverse
Solid Green: Full-speed forward
Solid Red: Full-speed reverse
Fault Conditions
Slow Flashing Yellow: Loss of servo link
Slow Flashing Red: Fault condition
Calibration Conditions
Flashing Red and Green: Calibration mode active
Flashing Red and Yellow: Calibration mode failure
Flashing Green and Yellow: Calibration mode success
it seems your jags are in a fault condition. check that they're not being overcurrented, and the power in is 12V DC. are you using black or grey jags?
Unread 01-02-2011, 15:10
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
The getting started guide here for the Jaguars tells you what the error codes mean. From that document, a slow flashing red light means one of the following:
- Power supply under-voltage
- Over temperature
- Over current
- Limit switch activated in the current direction of motion
I would start by checking the two limit switch jumpers are in place - that's probably the most common problem. If that's not the issue, disconnect your output leads to ensure nothing is shorted. Check the input leads to ensure you have sufficient voltage. Since it's when you start up the robot, I'm doubting it's a temperature issue.
Unread 01-02-2011, 17:43
imac256 imac256 is offline
AKA: Ian McInerney
FRC #2022 (Titan Robotics)
imac256 is a glorious beacon of lightimac256 is a glorious beacon of lightimac256 is a glorious beacon of lightimac256 is a glorious beacon of lightimac256 is a glorious beacon of light
The over current error is actually different then that. According to the CAN webinar at Kickoff, the over current error is a slow Red/Yellow blinking. The other errors are the slow Red blinking. Is this connected over PWM or CAN? If it is over CAN then see if you can use BDC-COMM to try to recreate the error, it will then tell you the error more specifically.
- Ian McInerney
Alumni & Mentor, Team 2022 Titan Robotics
Junior, Iowa State University majoring in Electrical Engineering
