Thread Tools |
Rating:
Display Modes |
#13
Re: Jaguar Speed Control Only Reaches 50% of Setpoint
Taken directly from the Jaguar source code:
// Compute the new control value.
llOutput = (((long long)psState->lPGain * (long long)lError) +
((long long)psState->lIGain *
(long long)psState->lIntegrator) +
((long long)psState->lDGain *
(long long)(lError - psState->lPrevError)));
Error is passed in to the PIDUpdate() function and is calculated as your Target Speed - Current Speed, Target Position - Current Position, and so on. Integrator is calculated every time PIDUpdate is called: Code:
// // Add the error to the integrator. // psState->lIntegrator += lError; Previous Error is the previously stored error. The PIDUpdate is called every time ControllerSpeedMode() is called (or any closed loop mode). Code:
// This function handles the periodic processing for speed control mode.
static void
ControllerSpeedMode(void)
[Omitted Code]
// Run the PID controller, with the output being the output voltage
// that should be driven to the motor.
lTemp = PIDUpdate(&g_sSpeedPID, lTemp) / 256;
[Omitted Code]
// Send the new output voltage to the H-bridge.
HBridgeVoltageSet(g_lVoltage);
// This function is called to handle the timer interrupt from the PWM module,
// which generates the 1 ms system timing.
void
ControllerIntHandler(void)
[Omitted Code]
// Call the appropriate control method based on the control mode
// that is currently enabled.
if(HWREGBITW(&g_ulFlags, FLAG_VCOMP_MODE))
ControllerVCompMode();
else if(HWREGBITW(&g_ulFlags, FLAG_CURRENT_MODE))
ControllerCurrentMode();
else if(HWREGBITW(&g_ulFlags, FLAG_SPEED_MODE))
ControllerSpeedMode();
else if(HWREGBITW(&g_ulFlags, FLAG_POSITION_MODE))
ControllerPositionMode();
else
ControllerVoltageMode();
[Omitted Code]
In each mode the error is in terms of the mode you're in (speed, current, position, voltage). When the PID is updated, the output is converted to a voltage command to the H-Bridge. |
